Oil cooler size and capabilities, HyperMotard?
Started by stopintime, March 02, 2011, 01:30:43 PM
The Febur looks very interesting [thumbsup] From the other forums it seems to be about $550 shipped. My only problem would be re-fitting my beloved dual oversized horns.
The EVO cooler is probably a lot taller - maybe too tall?
MotoWheels is out of stock on their cooler (right?)
I have to check if I really need it - quite $$$$'y
Yeah, the monster oversize oil cooler from Febur is listed as out of stock currently on the motowheels website.
errazor
Do You really need a bigger oilcooler? I live in Norway too and my max oil temp was 121 C the first day i ride my bike. Since that I have newer Seen it above118 C. what is Your max oil temp?
76 SUZUKI GT 100,  88 YAMAHA TDR 250,  07 DUCATI S2R 1000.
Quote from: a m on March 03, 2011, 01:58:15 PM
Ed is checking availability and pricing. I think theirs might be Febur - MW part # FE 163
Quote from: errazor on March 04, 2011, 08:41:36 AM
No issues normally, but the scenario I'm preparing for involves tuned engine with dB-killers.
I'll monitor the temperatures with the stock/HM cooler and compare with/without dB-killers.
errazor
I am running with the Termis, TPO beast and the DP ecu and thinking about ditching the oil cooler.
Really? What about idling in unplanned traffic?
Quote from: a m on March 04, 2011, 09:38:44 AM
We lane split  8)
Sitting in traffic it doesn't help much anyway, does it?
Not that I would ditch it, but.....
errazor
Too cold oil is not good, is it? I live in a smal town (trondheim) so I am out of traffic in 5 min.
no - i have seen people tape over or cover half of oil cooler if weather is not very hot
there is also the mocal thermostats - makes oil divert back before oil cooler if under certain temperature.
here i do not think an s2r1000 would make it through the summer without oil cooler
DarkStaR
I could probably run my s2r with out an oil cooler here.  I rarely ever pass the 150* mark while commuting, and just barely pass the 200* mark on spirited rides and through traffic.  :-\
errazor
Up here in the north 22 C is hot, we have 3 of these days in the year :P
Quote from: DarkStaR on March 04, 2011, 10:12:14 AM
F right, surely not C?
you forgot to circle the thermostat element that keeps the oil from over-cooling, shown just to the left of your box, directly after the in/out on the case.   I think evoluzione used to even manufacture one that was duc specific, but now I believe it is primarily a "rig something up" via generic parts task - a la the Mocal one.
I have no temp gauge...
my bike never runs hot or cold. ;)
I tape over the cooler to keep condensation out of the level window in cool temps.
See...
no overthinking here. ;)
