Termi's blocking oil drain plug
Started by kegan88, April 04, 2011, 12:54:37 PM
kegan88
Hey guys, this is my first post. I used to be over on the old monster forums but haven't been active anywhere since everyone left. I've got an 06 S4R with a full Termi system from DP. Sounds great, looks even better, couldn't be happier. Went to change my oil, and come to find out, the pipe from the front comes back directly under the oil drain plug, I mean, it's so tight against the bottom of the motor I can't even get a finger between them, I unhooked two of the mounting points and the header that connects to the front of the motor to try and finagle my way in and still without someone to pull down on the pipe I can't get in there. I've searched a couple places and all I can find is people acknowledging that this has been a problem for some, but no one has said anything about fixing it. I'm sure with a little help I can change my oil, but I can't keep unbolting my whole exhaust every 3k miles. Anyone have any advice as to how I can facilitate future oil changes?
m1moto
Quotebut I can't keep unbolting my whole exhaust every 3k miles
The #1 reason I chose to go with Arrows. AFAIK there is no fix.
2006 S2R1K  |  Red + White  |  Full Carbon Arrows
http://freshbrand.com/
mattc7
2 fixes
1: cut, buy pipe, bend it all,  weld back
2: remove and sell
kegan88
You'd think they would do a little R&D before charging people 1800 bucks for an exhaust, sort of ridiculous. The worst part is, a Ducati dealership installed them. You'd think during the install they'd be like "oh hey, there's no way to get the drain plug out." Definitely no good. Oh well, thanks for the quick replies guys.
muskrat
Zard, previously Termi employees  [thumbsup]
Or cannibalize under seat mount (high pipes) from an S2R 800/1000 and buy a Marvin mid pipe and vuala.....that's what I did.  ;D
Can we thin the gene pool?
2015 MTS 1200
09 Electra Glide
needtorque
I feel your pain on this one.  When I bought my S4R the previous owner had installed Sil Motor exhaust. A full system.  It also runs right under the oil drain plug.  Very irritating.  I will be purchasing a full Zard carbon system soon.  I think the Zards clear the plug fine which will be a side benefit to the main reason I am switching. (love the way the zards look)
Who insures the FDIC?
xcaptainxbloodx
Quote from: kegan88 on April 04, 2011, 01:27:57 PM
You'd think they would do a little R&D before charging people 1800 bucks for an exhaust,The worst part is, sort of ridiculous. a Ducati dealership installed them. You'd think during the install they'd be like "oh hey, there's no way to get the drain plug out." Definitely no good.
or maybe they thought you did research before dropping 1800$ on an exhaust? this is a known issue with these parts. did you ask them if there was any issue before you asked them to install the part YOU chose?
Heath
Wasn't one solution to put foil on the pipe during an oil change then take it off afterwards?  OR was that just the S2R800 pipe solution?
2007 Ducati Monster S4RT
Charlief
Quote from: Heath on April 04, 2011, 06:45:05 PM
The problem is the oil plug will not clear the pipe.  I have to drop my exhaust to change my oil. Pain in the ass!
Heath
Oh so you can't even get the plug out.  ouch..
DarkStaR
If you really:
1) Want to change your own oil for 1 reason  or another,
and
2) Don't want to make the beast with two backs with the exhaust every time you want to complete #1,
Pump the oil out.
Me on the other hand, I'd get a new exhaust.
Why not just pull the sump screen and tip the bike to the right a bit?
kegan88
Quote from: xcaptainxbloodx on April 04, 2011, 06:18:37 PM
Yeah, because I walked into my dealership and said "hey what problems will i have with this?" and they said "oh well, it sounds great, and it makes it physically impossible to remove your oil plug" your kidding right? Who's going to expect there is going to be a MAJOR issue with an exhaust specifically made and sold in a kit BY Ducati FOR a Ducati and installed AT Ducati? R&D is not the consumers job, it's the suppliers job, any other supplier on the market would have to fix this, or take it back, and if the Ducati dealership I had bought it from still existed, they'd be doing one of those.
I've thought about pumping the oil out and I've thought about just taking out the sump screen, but while i have the exhaust off it just seems most practical to fix the problem with a little bending.
Punx Clever
If you decide to sell the termi's, I would suggest NOT mentioning this fun little fact to the guy buying em... just saying  [thumbsup]
2008 S2R 1000 - Archangel
booger
Quote from: kegan88 on April 04, 2011, 10:49:32 PM
Guess you discovered the beauty of Italian product development, the hard way.
Coulda woulda shoulda. I can't see how a glaring problem like oil filter/drain plug access could get past anybody but maybe they didn't have a bike with that system on it for you to scrutinize before purchase. I like to examine and do some research before I plunk down $2k+ for anything. Didn't you bother? Well you have now learned a lesson.
It's Termignoni's fault for having their heads up their asses in the first place, Ducati's fault for selling badly designed factory authorized product in the second place, and your fault for buying it in the third place. Nobody ever said the Italians were like the Germans or Japanese. They get drunk on their lunch breaks and wouldn't ever think of committing harakiri if they made a mistake. To them, it's on you for buying their ill conceptions. They sleep at night just fine. Your experience is just a minor reason why I wouldn't consider Termignoni. Everybody else makes a better product that doesn't cost as much.
At any rate you're screwed unless you roll up your sleeves and do some work, either replace with something else or modify what you've got. I hope you fix it and post up when you're finished.
2001 M900Sie - sold
2006 S2R1000 - sold
2008 HM1100S - sold
2004 998 FE - $old
2007 S4RT
2007 Vespa LX50 aka "Slowey"
2008 BMW R1200 GSA
