February 14, 2025, 10:22:39 PM
Screwed up... time for Rearsets???
Topic: Screwed up... time for Rearsets??? (Read 2868 times)
dgm
May 19, 2011, 09:36:14 AM »
I've stripped the bolt hole in my 696's left side stock rearset where the pivot bolt goes for the shift lever.
It's stripped bad. I've tried the JB Weld trick, but so far, no luck. I'm wondering if I should just go to the rearsets that I really want, like the woodcrafts or metaltech, or if anyone has a better idea? I suppose I could also just scrap the stock shift lever and go with a GP Style shifter. Just trying to figure out what all my options are. I've got a track day in about 1 week, so whatever, I do, I need to do it quickly.
2009 696, Termi CF Pipes ECU Intake, Woodcraft Rearsets, Fender Elim, Shorty Pazzo Levers, CRG Lane Splitters, DP Low Seat, Powder Coated Bits, Speedymoto Frame Sliders, Rizoma Front Sliders, Rhinomoto Rear Sliders, Shorai Batt, Billet Oil Cap, iPhone Mount, LED Blinkers, Leggero Sprocket Cover, TPO Corsa Crankshaft Cover, Canister Delete/Euro Shroud, 14T Front Sprocket
DarkStaR
Re: Screwed up... time for Rearsets???
May 19, 2011, 09:42:45 AM »
A GP shifter will probably be the easiest solution if that suits your preference, and it can carry over even if you do end up getting new rearsets.
dgm
May 19, 2011, 09:49:54 AM »
Quote from: DarkStaR on May 19, 2011, 09:42:45 AM
good point. My only worry is having to learn a new shift pattern and then keeping it straight in my head when I move to/from my other two bikes with standard shift patters.
Some Dude
May 19, 2011, 10:16:18 AM »
You could use a thread insert. You would just need to drill out the hole larger, and tap it for the larger thread. Thread it in and tap down the locks. They are very easy to use.
http://www.mcmaster.com/#threaded-inserts/=cdid8n
Bike Info
99 m900s Sbk forks
41mm FCR's
Dyna coils
944 hi comp pistons
heads ported and polished
larger valves
new valves and cams
aluminum fly wheel & clutch basket
dgm
May 19, 2011, 10:29:30 AM »
interesting. Would a local hardware store sell these?
Some Dude
May 19, 2011, 10:31:47 AM »
Quote from: dgm on May 19, 2011, 10:29:30 AM
Maybe, Probably a fastner house like Fastenal
Bike Info
99 m900s Sbk forks
41mm FCR's
Dyna coils
944 hi comp pistons
larger valves
new valves and cams
Artful
I'm glad they make pills for my
May 19, 2011, 10:34:58 AM »
Timesert.
zooom
May 20, 2011, 08:10:24 AM »
Quote from: Artful on May 19, 2011, 10:34:58 AM
Timesert.
huge +1
2010 KTM 990 SM-T
May 20, 2011, 12:12:36 PM »
hey at least it's just your rearset. i think i stripped my case at the rearset/kickstand bolt
zooom
May 20, 2011, 12:19:20 PM »
Quote from: Raux on May 20, 2011, 12:12:36 PM
I did do that....because I kept spinning my bike around in parking spots on the kickstand and ended up fixing it with a Timesert and never made that mistake ever again!
2010 KTM 990 SM-T
May 20, 2011, 12:25:07 PM »
Quote from: zooom on May 20, 2011, 12:19:20 PM
yeah one of my kickstand bolts came loose, putting stress on the second. so i need to get the second fixed soon before i strip the first. fraking tq ratings ...whatever... nothing goes on the bike with out threadlock anymore.
dgm
May 21, 2011, 10:26:04 AM »
The timeserts look great and I've bookmarked them for future use. I decided just to go with woodcraft rearsets, since that's what I ultimately want anyway, but I may timesert the OEM one and keep as a backup. Hopefully my woodcrafts get here in time for me to install for my trackday next weekend.
