September 01, 2024, 06:21:07 AM
Please Help
So I pulled my spark plugs today...
Topic: So I pulled my spark plugs today... (Read 3931 times)
RubberDuckyS4
Newby learning the ropes.
May 23, 2011, 05:29:33 PM »
And found some oil on them
I went for a ride today and had some funky idle issues, and have had them intermittently lately. When I came to a stop it would sputter and die on me (which was not fun at the metering light to get on the freeway) so I started just trying to keep the revs up a little at stops until I got home to check out the motorcycle a little.
I'm new to Ducati's but not to basic engine know-how, is this a sure sign that I've got some seals that are failing and I'm getting oil into the combustion chamber? I did check Ducatisuite and it said pretty much that but I'd like some input from you guys and gals if you don't mind. Also I just bought this bike used and have no idea when the last tune up was, I'm in the process of changing all the fluids/spark plugs.
Here's the pics I snapped really quick:
Any help is appreciated, I'm gonna keep scouring the forum for answers in the mean time. Thanks!
Last Edit: May 23, 2011, 06:00:15 PM by RubberDuckyS4
Re: So I pulled my spark plugs today...
May 23, 2011, 09:39:44 PM »
What year and model of Monster?
64duc
May 24, 2011, 04:07:33 AM »
That is normal for my '94 900. Plug tip and insulator (which is where excessive oil in the cylinder would show up) look good.
94 M900, 64 Diana 250
RubberDuckyS4
May 24, 2011, 07:40:05 AM »
Its a 2002 S4 (916), I'm going to change them later today and play with my carbs a little and see if that helps the sputter.
May 24, 2011, 09:18:06 AM »
What model and heat range of plugs are those?
S4 was equipped with fuel injection, no carbs to play with.
RubberDuckyS4
May 24, 2011, 11:16:39 AM »
Quote from: Speeddog on May 24, 2011, 09:18:06 AM
Just made a quick assumption, obviously wrong...
. I don't have the plugs with me at the moment I'll reply with that later before I get some new ones. Do you think my plugs look bad, and if so could that be playing a part in my sputtering idle? Thanks Speeddog.
RubberDuckyS4
May 24, 2011, 01:18:36 PM »
The plugs are the original "Champion RA 59 GC" plugs. I don't see a heat rating on them and am having a difficult time finding some online.
May 24, 2011, 03:36:20 PM »
The OEM Champion RA 59 GC plugs are ~$30 each.
If you find them anywhere on line for less than that, please share.
I'd run 'em as is, they look alright.
I suspect your problem lies elsewhere.
How many miles on your bike?
RubberDuckyS4
May 24, 2011, 07:50:16 PM »
Its got 16,XXX on it.
bobtrude
May 25, 2011, 01:56:11 PM »
I bought theese and got them shipped to norway
. The shop wanted 40$ for one
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=170551879721&ssPageName=ADME:L:OU:MOTORS:1123
Great service and cheap plugs.
wiredbeans
May 25, 2011, 04:34:30 PM »
check the rectifier, and also the ground connection on the ECU
you never know. This is a common problem on the 1098
May 25, 2011, 06:01:06 PM »
Quote from: Speeddog on May 24, 2011, 03:36:20 PM
$8 each
http://www.rockauto.com/catalog/raframecatalog.php?catalog=12&partnum=1006&a=FR12-1006-2777
May 25, 2011, 06:06:36 PM »
Quote from: ducatiz on May 25, 2011, 06:01:06 PM
$8 each
Finally...
a lawyer with pertinent info.
May 25, 2011, 06:09:38 PM »
Quote from: ducpainter on May 25, 2011, 06:06:36 PM
Finally...
battlecry
On a silver black phantom bike...
Reply #14 on:
May 26, 2011, 05:15:11 AM »
You just crawled to the back of the line.
