October 07, 2024, 03:20:44 PM
Cant Start
Topic: Cant Start (Read 1166 times)
crude
We're alĺ addicts
Cant Start
June 03, 2011, 08:57:34 AM »
Hi folks,
I ride a 97' M900. It was alright starting 2 days ago but cant get it started today. Turned on the ignition and thumbed the starter button. There was the usual click sound (before the engine starts to turn), but then the lights and indicators on the dash went off. Checked the fuse box, was fine. Then I noticed a little square relay started buzzing beside the fuse box.
Any fix on this?
Thanks in advance
Duc 2003 M1000S
Honda NX650
YellowDuck
She knew I was no joke when she saw my
Re: Cant Start
June 03, 2011, 09:29:03 AM »
Yep, that's the starter relay, and it sounds bad. I had mine go and had to replace it, I'd suggest the same for you, although you can pop the top off to see what's going on. I think there is a part number cross for it in the alternative parts thread here:
http://www.ducatimonsterforum.org/index.php?topic=698.0
Also, if you do a search for starter relay or solenoid you'll get plenty of topics discussing your and other issues.
Last Edit: June 03, 2011, 10:19:56 AM by YellowDuck
bikepilot
Re: Cant Start
June 03, 2011, 01:26:22 PM »
It could also be a low battery - the relay will do that if it doesn't get enough juice. You can jump it off a car (with the car not running) to test or you can watch voltage while attempting to start (it shouldn't go much below 11v at any time).
2009 XB12XT
2006 Monster 620 (wife's)
1997 TL1000S
1975 Kawasaki H1 Mach III
2000 XR650R (dez racer)
2003 KX100 (wife's)
Re: Cant Start
June 03, 2011, 01:31:50 PM »
Quote from: YellowDuck on June 03, 2011, 09:29:03 AM
The starter relay is under the battery.
I think you mean main relay.
It can buzz if battery voltage is really low or if the relay is defective.
MongoReturns
I'm very busy
Re: Cant Start
June 03, 2011, 03:27:52 PM »
If you're cheap as dirt like me, take the relay apart & clean the contacts with fine wet&dry sandpaper. Use dry, of course.
2000Monster750Dark: cored pipes, stage2, 43t, f-18, dptach
2007 1098Red: home depot cooler guard, on sale cluch cover, on sale dp dark tall screen, ebay hugger, hand painted clutch spring caps
crude
We're alĺ addicts
Re: Cant Start
June 05, 2011, 06:37:21 AM »
Thanks folks,
it was the battery. Started just fine after charging it.
Duc 2003 M1000S
Honda NX650
