February 24, 2025, 08:30:43 AM *
News: Please Help
Author Topic: dry clutch case cover on a wet clutch  (Read 1562 times)
Roaduser
will be back on the road june 16
02 m800 with extras
« on: June 05, 2011, 08:12:27 PM »
will a clutch side engine cover with a sealed clutch cover fit on a baby monster with a wet clutch?
Cheers Clint
« Last Edit: June 07, 2011, 12:33:57 AM by Roaduser » Logged
zooom
« Reply #1 on: June 06, 2011, 06:53:12 AM »
will a clutch side engine cover with an sealed clutch cover fit on a baby monster with a wet clutch?
Cheers Clint
FIT? yes...work....no...not without serious work retrofitting a dryclutch complete set-up into your machine.
2010 KTM 990 SM-T
« Reply #2 on: June 06, 2011, 06:58:10 AM »
there's an inner seal on the dry clutch side cases that doesnt obviously exist on the wet clutch case AND the clutch isn't made to match up.
that's the technical reason ... but if you were going to switch to a dry clutch side case, why bother sealing it back up again?
Omnipotent Potentate
Personal Pretext
« Reply #3 on: June 06, 2011, 08:09:12 AM »
And not without the serious cost to go with it.
And BTW the cover on a dry clutch isn't 100% sealed anyway. There's a small gap at the bottom as a drain
Roaduser
02 m800 with extras
« Reply #4 on: June 06, 2011, 07:20:29 PM »
sorry guys, maybe i should explain a bit better.
i was looking at polishing one and i did not want to polish mine incase i dont like it. id rather keep my near perfect condition cover as is and polish another. im finding it hard to find a wet clutch side cover to polish so was looking at the idea of using a dry clutch side cover, sealing it up and polishing it.
would it be possible use it on a wet clutch motor if i cut out the part of the cover behind the basket and then weld up the drain hole and seal the clutch cover? i ask this as it seems easier and cheaper to source dry clutch covers.
Cheers Clint
« Last Edit: June 07, 2011, 12:28:54 AM by Roaduser » Logged
« Reply #5 on: June 06, 2011, 09:06:51 PM »
ebay it.... tons of them
Roaduser
02 m800 with extras
« Reply #6 on: June 06, 2011, 09:20:44 PM »
what are you searching under? i have been searching 'ducati clutch cover'  'monster clutch cover' 'ducati engine cover' and monster engine cover' and weeding through all the dry clutch covers. thats on us, uk and au ebays
today ive found the first wet clutch cover in the last two weeks!! ironically the day after i ask this question. and its too damaged to be polished.
« Last Edit: June 06, 2011, 09:23:53 PM by Roaduser » Logged
zooom
« Reply #7 on: June 07, 2011, 05:40:32 AM »
have you tried "ducati engine case" ?
2010 KTM 990 SM-T
Roaduser
02 m800 with extras
« Reply #8 on: June 07, 2011, 07:23:50 PM »
Huh? but i dont want an engine case, i want a cover. out of interest i tried searching that anyway and there is nothing there.
« Reply #9 on: June 07, 2011, 09:11:04 PM »
have you looked at these
http://cgi.ebay.com/ebaymotors/DUCATI-SILVER-ENGINE-CASE-SAVER-Monster-M-696-M696-848-_W0QQcmdZViewItemQQhashZitem43a0cee252QQitemZ290460721746QQptZMotorcyclesQ5fPartsQ5fAccessories
Roaduser
02 m800 with extras
« Reply #10 on: June 07, 2011, 09:19:02 PM »
i have seen them, the ebay and manufacturer only list the late model wet clutch engines as fitment, ie 696+, where as gotham cycles lists the early models too!?! but its still not the look i was after. i want the original cover polished.
corey
'06 Tang/Black S2R800
« Reply #11 on: June 08, 2011, 04:45:12 AM »
just keep an eye out for a side case (also known as a clutch cover) for a 620 or 750 or whatever. they pop up all the time.
or you could just sack up and do it to your own. if you don't like it, have it powdercoated black instead.
