February 15, 2025, 02:52:06 PM *
Pages: [1] 2   Go Down
Author Topic: Hella Supertone Horns... 1100M  (Read 5736 times)
Frustration
Insignificant Other
pezcyclingnews.com
« on: June 13, 2011, 02:07:49 PM »
 Evil
Yes,  There is a slight difference between these horns run here...  And the little Stocker run behind the Oil cooler.
I need to get a stock 1100 and make a sound clip from inside a car so folks can here the MASSIVE difference in the sound that reaches inside a car...
"I try to control baaat sometimes fast josta appen enyway"... VR46
ɹǝʌO d∩ uıɐןɐɹʇsn∀
Often wrong. Never in doubt.
« Reply #1 on: June 13, 2011, 08:35:59 PM »
I'm sure they make a vastly improved audible alert system  waytogo.
And the look?
Well....
..thats..
....that's...
......really somethin'...
Heath
« Reply #2 on: June 13, 2011, 09:55:54 PM »
Please tell me that is not where you are mounting them.
2007 Ducati Monster S4RT
TOB/DMF member since '02
« Reply #3 on: June 13, 2011, 11:08:29 PM »
 laughingdp laughingdp laughingdp
That's exactly what I'm looking for!!
Post a clip
« Reply #4 on: June 13, 2011, 11:12:26 PM »
Mickey Mouse LIVES
Frustration
Insignificant Other
pezcyclingnews.com
« Reply #5 on: June 14, 2011, 05:41:22 AM »
Looks not quite as bad from a relative perspective, but yeah, they're there...  no question.
Not for everyone for sure, but I kinda like the look and farkin love the music...
Fork clamps from a few different places work.  This was the only place on the forks that wont interupt air flow and or risk hitting the fender as the fork moves...  They're big suckers.
You also have to use the horn bracket metal (without bending it) that comes preinstalled to the horns to allow the horns to vibrate for full sound...  I talked to Hella and they said thats one of the most common mistakes is removing thos strips and mounting them differently.  A more solid mount dramatically cuts the vibes and volume...
The relay can be tacked right to the stock horn mount and use the stock horn plugs.
Power off the battery...
« Last Edit: June 14, 2011, 05:46:16 AM by Frustration » Logged
« Reply #6 on: June 14, 2011, 05:45:08 AM »
it's your bike and as long as you are happy
Frustration
Insignificant Other
pezcyclingnews.com
« Reply #7 on: June 14, 2011, 05:47:44 AM »
Part of what I like about Monsters...  Plenty of ways to go.
asherrick
« Reply #8 on: June 14, 2011, 08:57:43 AM »
And the look?
Well....
..thats..
....that's...
+1
'09 M1100s
NorDog
I don't feel like a
« Reply #9 on: June 14, 2011, 04:15:51 PM »
To each their own, but they really do, ah, stick out.
Horns should heard, not seen, imo.
I bought this set...
...hit 'em with some rattle can paint and mounted them below the front signals.
Paid under $17.00 for the set (with relay included) back in '08.  I think they run about $20 now.  The included mounting tabs actually worked perfectly for that mounting location.
The only draw back is that I can't use them around cemeteries because they wake the dead.
« Last Edit: June 15, 2011, 07:27:11 AM by NorDog » Logged
Frustration
Insignificant Other
pezcyclingnews.com
« Reply #10 on: June 14, 2011, 04:17:38 PM »
nice disappearing...
better pic than the camera phone.
Mhanis
« Reply #11 on: June 15, 2011, 05:02:40 AM »
Howcome you have a wrist band around the brake fluid reservoir?
Pete Townshend
DucNaked
« Reply #12 on: June 15, 2011, 05:09:57 AM »
Is this what you were going for?  Grin
« Reply #13 on: June 15, 2011, 05:32:24 AM »
sound clip! do u need to run both? or is 1 sufficent? hows it compare to a stebel???
DucHead
No garage queens
« Reply #14 on: June 15, 2011, 06:40:30 AM »
Add a stuffed toy to the windscreen and you're all set!
Pages: [1] 2   Go Up
