October 02, 2024, 08:49:27 AM
1199 Photo leak!
21
22
23
24
28
Topic: 1199 Photo leak! (Read 83075 times)
77south
Re: 1199 Photo leak!
Reply #315 on:
October 10, 2011, 05:56:54 AM »
Oh. thanks for the clarification about the springs.
Reply #316 on:
October 10, 2011, 08:10:03 AM »
Quote from: Sad Panda on October 10, 2011, 04:37:00 AM
Power Delivery
_Integrated design for engine & vehicle: the new Superquadro engine is a fully stressed member of the chassis
_Racing oriented pistons: double ribbed and RR58 alloy
_
Secondary Air System
_New chain drive timing system
_Slipper and self-servo wet clutch
_New gearbox: increased dimension between shaft centers for increased strenght
That's the system I had to remove from the Super Duke to keep it from back-firing (quite loudly) every time you let off the throttle.
Reply #317 on:
October 10, 2011, 08:16:45 AM »
Quote from: DRKWNG on October 10, 2011, 08:10:03 AM
apparently its a backfire onpurpose in the exhaust system to burn any left over fuel for cleaner emissions
Reply #318 on:
October 10, 2011, 08:19:39 AM »
Quote from: Raux on October 10, 2011, 08:16:45 AM
Pretty much. It injects "fresh" air into the engine, just prior to the exhaust port. So basically it tricks the emission "sniffers" into thinking it's running leaner.
And I'll tell you from first hand experience, all that back-firing gets pretty irritating.
Reply #319 on:
October 10, 2011, 08:22:54 AM »
Quote from: DRKWNG on October 10, 2011, 08:19:39 AM
thought i read after the exhaust ports
Reply #320 on:
October 10, 2011, 08:23:55 AM »
Quote from: Raux on October 10, 2011, 08:22:54 AM
On the 1199? Maybe. I was speaking about the LC8 motor with that comment.
Reply #321 on:
October 10, 2011, 08:43:31 AM »
Quote from: DRKWNG on October 10, 2011, 08:23:55 AM
i know
Omnipotent Potentate
Personal Pretext
Reply #322 on:
October 10, 2011, 09:43:55 AM »
Video on the engine
So after watching that I'm wondering if this
_Secondary Air System
is the new Vacuum system they mentioned. Some special gizmo to keep the vacuum pressure in the case constant. Could still be that emissions thing like in the LC8 too... hmm
Last Edit: October 10, 2011, 09:49:34 AM by Sad Panda
Reply #323 on:
October 10, 2011, 09:51:11 AM »
Quote from: Sad Panda on October 10, 2011, 09:43:55 AM
Video on the engine
2:43
"for the first time in a ducati engine we have introduced a chain driven cam"
uhh. no..
Reply #324 on:
October 10, 2011, 10:41:02 AM »
Quote from: ducatiz on October 10, 2011, 09:51:11 AM
2:43
uhh. no..
Bet they forgot about that one. As memorable as the Indiana
Reply #325 on:
October 10, 2011, 11:19:49 AM »
Quote from: howie on October 10, 2011, 10:41:02 AM
Which is surprising given they have a cutaway model of the engine in the Corse room. When I went there for an investors' tour, they took us in and it was the first one on a stand to the left. I doubt it's in that spot still, but hard to miss..
Reply #326 on:
October 10, 2011, 01:00:40 PM »
Video on the engine
The size/shape/locations of the plates look just the same as the ones on the LC8, as do the fittings (seen center screen at 2:52). I'm willing to bet this is the feature that they were referring to which allowed the cleaner emissions.
Last Edit: October 10, 2011, 01:03:51 PM by DRKWNG
muskrat
Reply #327 on:
October 10, 2011, 01:01:45 PM »
and the tank?
Can we thin the gene pool?
2015 MTS 1200
09 Electra Glide
zarn02
Reply #328 on:
October 10, 2011, 02:16:00 PM »
Quote from: muskrat on October 10, 2011, 01:01:45 PM
and the tank?
Is made of paper, held together by bird spit.
Reply #329 on:
October 10, 2011, 02:28:19 PM »
Quote from: zarn02 on October 10, 2011, 02:16:00 PM
It could be spit from an eagle.
21
22
23
24
28
