August 25, 2024, 06:19:27 AM
1199 Photo leak!
22
23
24
25
28
Topic: 1199 Photo leak! (Read 82244 times)
Re: 1199 Photo leak!
Reply #330 on:
October 10, 2011, 02:59:09 PM »
Quote from: DRKWNG on October 10, 2011, 02:28:19 PM
It could be spit from an eagle.
A radioactive eagle on steroids infused with tiger blood.
NorDog
I don't feel like a
Reply #331 on:
October 10, 2011, 04:05:11 PM »
Quote from: ducatiz on October 10, 2011, 02:59:09 PM
But what if it's facing to the left?
Reply #332 on:
October 10, 2011, 04:16:04 PM »
Quote from: NorDog on October 10, 2011, 04:05:11 PM
Even...
Worse....!
matt922
Reply #333 on:
October 10, 2011, 05:12:55 PM »
they now have 1199 "panigale" on the sbk line up on the site.. coming soon
Howley
Reply #334 on:
October 11, 2011, 04:50:06 AM »
Hooray!! It's back again!
loves ze desmodromics.
Reply #335 on:
October 11, 2011, 08:55:39 AM »
Back to the 1199 & Gas Charged Forks - they are shown on the bike in this teaser video at the 43s mark:
duccarlos
Reply #336 on:
October 11, 2011, 09:35:11 AM »
Quote from: j v on October 11, 2011, 08:55:39 AM
Almost as cool as this picture... almost.
http://redux.com/stream/item/789086/Laser-Wolves
Reply #337 on:
October 11, 2011, 09:39:10 AM »
that's a left handed guitarist wolf?!
thought
Everyone needs a
Reply #338 on:
October 11, 2011, 06:13:14 PM »
hell for leather is saying 15k service intervals too
'10 SFS 1098
'11 M796 ABS - Sold
'05 SV650N - Sold
Randimus Maximus
'01 996SPS
Reply #339 on:
October 11, 2011, 09:00:04 PM »
Quote from: Howley on October 11, 2011, 04:50:06 AM
you may be a god
MadDuck
The anti-
Reply #340 on:
October 11, 2011, 10:18:55 PM »
Quote from: thought on October 11, 2011, 06:13:14 PM
One huge question is nagging me in the back of my mind. Considering that the proposed airbox is part of the forward frame section, including the steering neck, and that this whole sub assembly bolts onto the top of the horizontal cylinder and to the top of the vertical cylinder what happens when it comes time to adjust valves..........? Does the whole front & top of the bike have to be stripped off to remove the valve covers? Just curious...............
MadDuck
The anti-
Reply #341 on:
October 11, 2011, 10:26:52 PM »
Quote from: DRKWNG on October 10, 2011, 08:10:03 AM
That's the system I had to remove from the Super Duke to keep it from back-firing (quite loudly) every time you let off the throttle.
Secondary air system is an emission related system. On cars it usually affects the cold engine running and is shut off as engine temps climb to operating temps. Can't speak exactly for the motorcycle system though except that it promises to be another pain in the butt to deal with when it's not working properly.
The vacuum pump in the crankcase is completely different from the secondary air system and mostly reduces internal crank pressures caused by the action of the pistons compressing air in the cases when the pistons travel downward. This vacuum action would reduce crank blow by pressures. Ducati also refers to the vacuum as helping scavange oil back into the lower crank area but I dunno if that is a major design feature or a left over benefit.
Reply #342 on:
October 11, 2011, 10:32:09 PM »
Quote from: MacDuck on October 11, 2011, 10:18:55 PM
if u look closely at the photos u can see the mounting bolts for the front
I'm going to guess thar most of the bike will have to come apart
hopefully the will put connectors for the wiring at easy to reach places
Reply #343 on:
October 12, 2011, 03:59:04 AM »
Quote from: MacDuck on October 11, 2011, 10:26:52 PM
Yep. Burning farts twice. Air injection systems on cars used to run constantly. On cold starts only since the mid 90's. Check valves prevent backfire on decel and shifting.
More likely necessity.
Reply #344 on:
October 12, 2011, 12:41:48 PM »
Exactly. On the LC8, it's there to inject "fresh" air into the exhaust system, post combustion. That way the gasses coming out the pipe are "cleaner" and the bike passes emission standards.
22
23
24
25
28
