2001 750 SS ...runs great but pops some ?
Started by H-2 CHARLIE, July 10, 2011, 08:06:17 PM
H-2 CHARLIE
the bike is a 2001 750 and it runs great its F.I.  so it idels fine revs great but it pops or almost sounds like its starting to run out of gas or grounding out or   ? it does it when you gas it and it starts ot pop but really dont effect the power load .i am running a sock over the velisity intake which it came this way from PO. IS IT A STRECHED TIMING BELT ? It does it after about 5-10 min afeter on the road ....ANY ONE WANT TO COMMENT ?
H-2 CHARLIE
wow ..18 views and no feed back ...I did a search on emmisions removel and the end caps are a must to be pluged and i did see a open nippel under the bottom of the injector that was off ...I  will plug this nipple and check both and i will see /// feed back comming soon .
The popping is coming from the exhaust? Does is pop more under certain conditions that others? IE under engine breaking/decel?
Did you make any changes right before this condition began?
Quote from: H-2 CHARLIE on July 11, 2011, 09:48:30 AM
You original post is pretty hard to follow man. And getting grouchy about a few people viewing and not giving any response isn't a way to endear people to you. The active population on the board isn't huge -  patience.
What RPM?  My 900SS would do that  just under 4K.  I was attributing it to the factory lean map since it didn't really affect anything else ~
JM
H-2 CHARLIE
  OK it happened more when i rode it on a hot day  ... then under hard throtle under low RPMs it still did it .. to nite it did it just a little bit on a shrort ride a few towns over but not near as bad as on a hot day .  This would great to get fixed but  i can live with it ... it does idle fine and rev great but under a load even on  a fast rev it might do it .
My 900SS would pop when you hovered in the general 3500-4200 RPM range, but I didn't notice it if I really twisted on it.  It really could be the factory lean map.
JM
zarn02
They do come lean from the factory.
Any other mods? Freer-flowing exhaust or intake? Both?
H-2 CHARLIE
#7
  The mods are a short yosh pipe and lt has canvas stuff zip tied over the intake runners . I did  find the one nipple open on the intake runner , it has a very tiny pin hole on the end so i red temp glued  it with a tight rubber cap . I have not had a chance to ride it but tommorow i will report back and see .
