February 12, 2025, 12:15:12 AM *
News: Please Help
Author Topic: Clutch cover dent  (Read 967 times)
Betlog
« on: July 14, 2011, 02:20:16 PM »
Hi guys,
Minor cosmetic issue here... it appears my clutch cover (S2R800 wet clutch) has what looks like a "dimple" on the side.  I'm wondering if this was due to casting/manufacturing as there's no visible paint damage.  The other possible cause is that it was hit by a blunt object?  How durable are these and would they dent like this if it were hit?  I guess, if you all don't mind, can you check out your wet clutch bikes and see if you have this same "dimple"?
« Reply #1 on: July 14, 2011, 03:50:58 PM »
My 1999 M750 does not. I wouldn't be too concerned with it, it probably doesn't affect anything.
JM
Betlog
« Reply #2 on: July 14, 2011, 08:41:13 PM »
JM
Thank you for checking.  Any other deformities on your clutch cover not unlike mine in different areas?
Anyone else?
xcaptainxbloodx
« Reply #3 on: July 14, 2011, 09:23:12 PM »
my s2r800 has been down on the clutch side twice, as long as its holding oil the thing is pretty much indestructible, I wouldnt worry about it unless you are having an issue with your clutch or looking to powder coat it.
the other side of that case has a steel plate and a rubber "silencer". it would take a pretty severe knock to really affect anything.
Betlog
« Reply #4 on: July 14, 2011, 10:20:46 PM »
Thank you.  That's good to know about the inside of that case.
