Doworkson's 696 dual headlight, and other mods...
Started by DoWorkSon, August 08, 2011, 10:55:32 AM
DoWorkSon
Quote from: NateNewThread on August 15, 2011, 05:55:55 PM
I'm a bit confused at how you mount the headlight bracket to the CNC clamps.
There is a small threaded hole on the Cnc clamp you cannot reall see...
Bolt goes through headlight bracket, through a spacer, and screws into this threaded hole... The collars come with small spacers to offset the bracket from the forks..
Kinda hard to explain, but makes since when you see them
2009 M696--SOLD
toodlepip
This mod address's one of the main things I dislike about the "new" monsters. Looks freakin awesome!
COP TZR
what kind of paint did you use on that oil cooler?  I want to do mine, but not sure if painting it will have an adverse affect on the cooling properties.
DoWorkSon
Hi temp spray paint... However, if I did it again, I would prep it much better, powdercoat It or go with ceramic coating
2009 M696--SOLD
Quote from: DoWorkSon on August 16, 2011, 09:05:01 AM
Be sure to use a coating that will transmit the heat, not insulate. Some coatings will act as an insulator.
COP TZR
Quote from: Sad Panda on August 16, 2011, 09:09:19 AM
will B.B.Q. paint work?
2-Skinny
I think he used BBQ paint for first application and touch up with VHT caliper paint...
COP TZR
how is the light output with these lights?   Better than stock single or better?
cokey
There's a coating you can use which attracts heat away from the metal...  we use on engine internals and intake manifolds..
I WIN
About the goat...
kocheroni
Quote from: zarn02 on August 08, 2011, 09:41:50 PM
You can kind of find a "mouth" between the lower triple and the fender. The face it's making doesn't look happy, though. [laugh]
[laugh] ... I somehow see this...
NateNewThread
Quote from: COP TZR on August 17, 2011, 06:00:15 AM
I have the same lights. To me they seem to have a little less brightness than the stock one and the spread is also a little less.
That being said they are still really good headlights. They provide plenty of light. I also have a sneaking suspicious that I haven't adjusted mine correctly yet.
jgrimm
Your bike is gorgeous. Where did you get the belly pan? I tried to order one off of Xcentrik's website but there website SUCKS!!! Dont know if I trust it.
DoWorkSon
Quote from: jgrimm on September 24, 2011, 09:47:31 AM
Thanks!
I ordered through their site... As bad as it is, they had great customer service and made sure to update me and made sure it all worked out... Just expect awhile for delivery
2009 M696--SOLD
