Project 900SS/SP refresh
Started by TAftonomos, August 13, 2011, 10:39:35 AM
Quote from: TAftonomos on October 24, 2011, 05:09:27 AM
Dowel pin, that goes between the cylinder and head.
i'll look around.. i might have one from a 620 engine i just tore down, should be the same.  cost you one can of beans.
TAftonomos
TAftonomos
Friday's list:
900SS engine assembly
-remove jugs/pistons
-machine pistons, 3mm off the top
-recheck ring clearance
Assemble dry without base gaskets
Check squish clearance â€" 1.0mm or .040” clearance MIN
Assemble without base gasket if possible
Torque down heads
Install belts and time engine
900SS roller assembly
Install swingarm into motor
Bolt up shock
Install loosely on frame
Machine engine case and frame for 12mm engine bolts
Install rear wheel
Install front wheel
Roller assembly complete
Install carb manifold
Install carbs AFTER checking existing jetting â€" 165mains 60 pilots 4th notch on needles
Install pod filters
TAftonomos
What really happened Fri:
Life
Waited for 2 hours at the bank to cash a stupid check
Drove to the dealer to pickup the S4Rt.
Stuck in traffic for 3 hours on the way home
Beer
Sleep
Will try for tomorrow
Oh...did I mention the dealer who told me he had a dowel pin for me.....didn't.  Gee, thanks.  I get to wait another week now.
Quote from: TAftonomos on October 28, 2011, 08:56:57 PM
nothing special about them
call these guys
http://www.radax.com/store.asp?pid=14584
ask for samples
greenmonster
Quote165mains
Are those Dynojet or Mikuni jets?
M900 -97
MTS 1100s  -07
TAftonomos
Quote from: ducatiz on October 28, 2011, 09:11:01 PM
call these guys
ask for samples
I suppose I could do that.  And just drill a hole same size as the other one. (Oil feed I believe)
Thanks!
Those are jets for the FCR's
Quote from: TAftonomos on October 29, 2011, 07:33:53 AM
Thanks!
they might have them
TAftonomos
#83
Doing some work:
Indexing the pistons
Vid showing the cutting
Head is on now, with solder to ch\
check squish (no base gasket)
Break for lunch - done
Headed to lowes to buy a 15mm wrench...so I can make another head nut torque tool.  14mm would have been nice here ducati (so I could use the other one I just made weeks ago)
TAftonomos
Squish measured out at 1.06mm on the tightest portion, 1.10mm on the largest part.  Looks like I'm good to go w/o base gaskets :D
I want to confirm the orientation of the piston before I button it up completely.....
Can someone look at the above pic and let me know if the piston is oriented the correct way?  Intake on left.  The depth measures the same, but the done is biased towards the right (exhaust) side.
brad black
Brad The Bike Boy
http://www.bikeboy.org
TAftonomos
It's a roller now.
Some leftover Ti bolts I had laying around.  Looks like I need to order some washers too.  Spring was 5 mins with a wire brush/drill and some WD40.
that kickstand bolt looks like shit.   ;D
is the swingarm aluminium or steel?  I can't tell it looks like one of the box alu ones.  powder coated?
you can use either 14 or 15 mm nuts, i think mdmetric has the right type of 10.8 nuts.
the 14mm wrench is much easier to work with, 1mm is a lot in that space..
TAftonomos
Aluminum arm, PC'd
I just ordered a TPO kickstand nut, thanks  [bang]
I made a tool from some kobalt junk.  Actually it may not be junk after all...tore up a dewalt sawzall blade trying to cut it down to size.
