February 20, 2025, 06:37:13 PM *
Pages: 1 [2] 3   Go Down
Author Topic: How to get the rear wheel off the ground without a paddock stand  (Read 9280 times)
« Reply #15 on: August 24, 2011, 06:00:02 PM »
If you've got a buddy to help, you can use the side stand as a lever and lean the bike on the front wheel.  Works in a pinch.  Jump to the 5:05 mark in this Keith Code vid:
nope nope nope
JEFF_H
« Reply #16 on: August 25, 2011, 01:15:37 PM »
Roll Eyes bad idea I guess, scratch that.
dont feel too bad.
worse idea is lubing the chain with the bike in gear and turning the rear wheel
hillbillypolack
« Reply #17 on: August 25, 2011, 04:48:12 PM »
You have a premium motorcycle.  Invest $70 in a welded tube rear stand.
Levering the bike around on the sidestand can crack the engine case (as was mentioned earlier) and you really don't want that.
Jacking the bike up from below is likely going to involve contact with the case or header pipe beneath the bike (am I right?).  Also not a good idea since you may cause the bike to tip, crack the case or tweak the exhaust.
I know rolling the bike around while lubing or cleaning the chain isn't convenient, but until you get a rear stand it's better than causing possible damage.
Punx Clever
« Reply #18 on: August 25, 2011, 05:19:19 PM »
http://www.harborfreight.com/automotive-motorcycle/shop-cranes.html
2008 S2R 1000 - Archangel
avizpls
TECH
« Reply #19 on: August 25, 2011, 06:16:22 PM »
Tell me you're joking.
Try this instead
There's a coupon in rrw for 25 I think!
2-Skinny
Head Mechanic, Technical and Research Consultant
Measure Twice, Cut Thrice...at least...
« Reply #20 on: August 25, 2011, 06:58:58 PM »
http://www.harborfreight.com/low-profile-rear-motorcycle-spool-stand-99701.html
J5
I'm here to fix zee fridge
« Reply #21 on: August 25, 2011, 10:47:55 PM »
useless for SSS
http://www.hardlineproducts.com/products/rollastand.html
(rear wheel stand would be better....)
quite a good option as can use it forever on any bike and good for long distance travel
« Reply #22 on: August 26, 2011, 06:06:36 AM »
Front and rear stand, all in one
http://cgi.ebay.com/ebaymotors/120766857818?
$53 shipped
I have two now and I have zero problems.  They are not heavy like the bulldog but they do the job for a much lower price.
« Last Edit: August 26, 2011, 06:10:58 AM by ducatiz » Logged
Punx Clever
« Reply #23 on: August 26, 2011, 10:04:00 AM »
Only kinda.  I like using the engine hoist.
avizpls
TECH
« Reply #24 on: August 26, 2011, 10:27:39 AM »
yeah, but if youre spending that kind of money.....get the correct stand!
I used (not an engine lift) but an overhead beam before I bought a stand, so I know what thats like.  chug
Punx Clever
« Reply #25 on: August 26, 2011, 10:56:57 AM »
When I bought the one I have now (used to use the hoist in my dads shop), I weighed the pros and cons of buying a set of stands vs a hoist.  The hoist allows for everything from a complete rebuild to oiling the chain.  Only thing a hoist doesn't do that a stand does, is storage.
freeclimbmtb
From Zero Member to
« Reply #26 on: August 26, 2011, 11:03:51 AM »
if you put the pipe through the axle while its on the side stand and adjust the right jackstand to fit, then you can lever the whole bike up by the pipe and slide the left jackstand under.  works for the front too  Grin
...of course this is ideal for cleaning and lubing...not very practical if you need to take the tire off....
...and sorry all you HD guys out there...you need hollow axles for this trick laughingdp
« Last Edit: August 26, 2011, 11:05:29 AM by freeclimbmtb » Logged
2011 Monster 796 ABS
Narflar
Beware the wrath of my
Professional Lurker
« Reply #27 on: August 26, 2011, 01:18:29 PM »
$53 shipped
How does that work with a SSS?
2012 Ducati Monster 1100 Evo
2008 Honda ST1300
2008 Triumph Speedmaster
2004 Ducati M1000
hillbillypolack
« Reply #28 on: August 26, 2011, 05:24:25 PM »
I'm gonna need pics to see what you mean.
My mind is just jogging through images of a raw pipe on painted metal, flaking off the original surface.  Owch.
DarkStaR
« Reply #29 on: August 26, 2011, 05:34:07 PM »
Through the axle.  No paint normally in there....
Pages: 1 [2] 3   Go Up
