How to get the rear wheel off the ground without a paddock stand
Started by godudi, August 24, 2011, 11:08:34 AM
godudi
Hi
I own a Ducati Monster 1100 EVO (single sided swing arm) and I wonder if there are other ways to get the rear wheel off the ground without a rear stand so I can easily clean and lube the chain?
Please share your ideas,
Thanks,
David
avizpls
got an overhead I beam?
and a few ratchet straps?
Take your seat off and find a sturdy spot to hook onto. The higher on the bike the better, and make the points on the I beam wide apart (at least 4 feet)
Bike will sway, but its doable.
I see your edit and raise you my own: just to lube chain? Have someone sit on the bike and slowly move it for you. the above isnt worths unless you need to remove the wheel.
#11
godudi
Quote from: avizpls on August 24, 2011, 11:14:07 AM
I don't have an overhead I beam nor someone to sit on the bike and move it for me.
avizpls
then I'd say you're going to have to clean what chain is accessible, get up and move it so a fresh section of chain can be attended to....repeat as needed until  all 98-102 links are complete.
#11
godudi
Quote from: avizpls on August 24, 2011, 11:36:46 AM
This is exactly how I clean it today, and it is very annoying and not practical :(
godudi
Can I just use a regular floor jack under a certain point and jack the bike up just enough for the rear tire to spin, yet still to be supported by the jack, sidestand, and front tire?
J5
Quote from: godudi on August 24, 2011, 11:58:53 AM
thats exactly how you can do it
godudi
Quote from: J5 on August 24, 2011, 12:13:12 PM
So now the question should be which part of the bike should I attach the floor jack to/?
DarkStaR
Save yourself the trouble and get a rear stand.  It's worth it.
OneWheelDrive
If you've got a buddy to help, you can use the side stand as a lever and lean the bike on the front wheel.  Works in a pinch.  Jump to the 5:05 mark in this Keith Code vid:
2005 Vespa LX150 --> 1971 CB500 --> 1978 CB750 Cafe --> 1973 CB550 Racer --> 2007 S4RS: IL MONSTRO!
OneWheelDrive
DarkStaR
Not the best idea for a duc, as the side stand is connected to the engine case.  Problems can and have occured which can result in $$$ repairs.
avizpls
Yeah, definitely do not lean it on the kickstand.
Get a rear stand or do it how you do now.
#11
OneWheelDrive
