February 20, 2025, 07:08:18 PM *
Pages: 1 2 [3]   Go Down
Author Topic: How to get the rear wheel off the ground without a paddock stand  (Read 9283 times)
freeclimbmtb
From Zero Member to
« Reply #30 on: August 27, 2011, 04:59:58 AM »
I'm gonna need pics to see what you mean.
My mind is just jogging through images of a raw pipe on painted metal, flaking off the original surface.  Owch.
Unfortunately I'm 3000 miles away from my garage until december, but darkstar is right, theres no paint on the inside of your axle, and even the ducati performance rear stand for the SSS bikes uses a raw steel stepped pin that goes into the axle...no less harmful than a piece of pipe.
2011 Monster 796 ABS
Rameses
*Your Mom* has a Hypermotard
« Reply #31 on: August 28, 2011, 07:41:18 PM »
Like this, except you slip a pipe or bar through the hollow axle instead of using the spools.
Also, if you have rigid, non-hinged footpegs, you can just put the jackstands under the pegs.
« Last Edit: August 28, 2011, 07:43:40 PM by Rameses » Logged
Mojo S2R
. Dark Mojo .
« Reply #32 on: August 28, 2011, 07:46:47 PM »
Stoppie?
Won't really work for oiling the chain though.  Or any other maintenance for that matter.  Grin
Rameses
« Reply #33 on: August 28, 2011, 09:08:56 PM »
Stoppie?
Maybe for draining the fork oil.   Grin
« Reply #34 on: August 29, 2011, 04:31:29 AM »
I love that pic.  Best Helmet Ever.
But I wonder how it fared when he faceplanted 0.25 seconds later?
timeforpoptarts
« Reply #35 on: August 29, 2011, 04:54:19 AM »
Front and rear stand, all in one
http://cgi.ebay.com/ebaymotors/120766857818?
$53 shipped
I have two now and I have zero problems.  They are not heavy like the bulldog but they do the job for a much lower price.
Does this fit the newer Monsters with axle sliders in?
'11 M796 ABS
SDkid
« Reply #36 on: August 30, 2011, 07:14:51 PM »
he needed to have his helmet off to show that facial expression.  EVERYONE else behind him had at least a helmet on...bad luck vs. stupidity.
« Reply #37 on: August 30, 2011, 07:29:14 PM »
No idea.  I picked it up for the front capability, but I think it comes with paddles for the swingarm.
Pages: 1 2 [3]   Go Up
