January 15, 2025, 12:53:09 AM *
Pages: 1 ... 60 61 [62] 63 64 ... 72   Go Down
Author Topic: You're too stupid to... own a diesel small truck  (Read 260068 times)
« Reply #915 on: March 23, 2016, 10:02:08 AM »
And so this isn't totally off topic... I have a 4 cylinder turbo diesel that I'm rebuilding to put in one of my CJ-2As.  Grin
Now that sounds like fun! Where'd you source the motor?
Rameses
*Your Mom* has a Hypermotard
« Reply #916 on: March 23, 2016, 08:25:24 PM »
It's a Shibaura N844T out of a New Holland LS170 skid steer.
« Reply #917 on: March 24, 2016, 10:31:50 AM »
You're putting a "bobcat" motor in your Jeep?
Online Online
« Reply #918 on: March 24, 2016, 01:27:04 PM »
If you can make it fit, why not?
« Reply #919 on: March 24, 2016, 01:40:29 PM »
Just didn't seem like it would be the ideal motor. I would imagine the expected duty cycle would vary too greatly for the two different applications.
Rameses
« Reply #920 on: March 24, 2016, 08:29:28 PM »
They're made to run wide open for 8 hours at a time.
Why would duty cycle be a concern?
« Reply #921 on: March 25, 2016, 07:14:03 AM »
Really? Wide open? I had no idea...
Rameses
« Reply #922 on: March 25, 2016, 10:08:13 AM »
Yeah, most construction equipment has a throttle lever (fancy newer stuff has a dial or push button control) and you either set it to 100% or an idle.  Full throttle gives you maximum power in your hydraulic system, and machine travel speed is controlled via a hydraulic valve, variable geometry pump, or hydrostatic transmission.
So when a machine's being used in production work, and the operator isn't constantly getting on and off the machine, or waiting on trucks, or the like, it's running wide open until it's time for a break or you have stop for fuel (or water, depending on what the machine is).
Feral 859
« Reply #923 on: March 25, 2016, 10:14:25 AM »
Ok. Splain why this type of engine is not used in vehicles.
For $50 you can touch my
« Reply #924 on: March 25, 2016, 12:58:43 PM »
I assume due to the cost of said type of engine.
https://www.pilotengines.com/engines/engines-by-manufacturer/shibaura/n844tls170a
Rameses
« Reply #925 on: March 25, 2016, 01:39:08 PM »
Also probably something to do with emissions.
« Reply #926 on: March 25, 2016, 01:51:46 PM »
The New VW Bobcat!
Feral 859
« Reply #927 on: March 25, 2016, 02:47:47 PM »
Ahhh, grasshopper.  Wink
Rameses
« Reply #928 on: March 27, 2016, 09:10:06 AM »
Hope this isn't a derby...
http://pages.ebay.com/motors/link/?nav=item.view&id=152030792984&alt=web
Rameses
« Reply #929 on: March 27, 2016, 09:17:35 AM »
http://pages.ebay.com/motors/link/?nav=item.view&id=172143089259&alt=web
« Last Edit: March 31, 2016, 05:03:38 AM by Rameses » Logged
Pages: 1 ... 60 61 [62] 63 64 ... 72   Go Up
