Right Hand Going Numb
Started by Steve.In.Atlanta, September 25, 2011, 11:28:11 AM
Steve.In.Atlanta
I was out on the bike for a couple of hours on the interstate riding and my right hand kept going numb. It's been a while since I've driven a motorcycle for distance on the highway and looking for some solutions.
When I got out of the navy in '92 I drove a motorcycle from Newport, RI to Chattanooga, TN without a lot of difficulty. I had a throttle lock on there that I would use to lock the throttle so I could shake my hand a bit to keep that from happening. I have no idea where I got that thing or what it was called.
Do you guys think that's a good item or is there another solution?
2005 Monster S4R
2001 Monster 900S (stolen)
DuctheMonster
Sometimes I have the same issue, I find that if your wrist is making more of a 45 degree angle (bent) then you don't get as much blood flow... If you try and keep your wrist straight the pressure from your weight on the handle bars shouldn't be as bad keeping your blood flowing. Kind of works for me... give it a try.
positivecarry
Relax your grip...a trick I use is to make sure your grip is loose enough that you can touch your thumb tip to your index finger tip.  Basically, practice using as light a grip as possible.
Duc796canada
It sure sucks! I had it bad yesterday to were I could apply the front brake, lucky I was on the country roads. Sorry to hijack your post, but anyone know if you can use that palm rest thingy with bar-end mirrors on?
796 Red Monster(sans ABS)
Viz-Tec Supabrake II
15/41 gearing(AFAM quick change sprocket)
PC V, NEXTUP QS.
2006 Suzuki GSXR 600 track bike(I know...not a Duc...some day)
Steve.In.Atlanta
I was thinking about using a palm rest. I can't see why it would interfere with bar-end mirrors. The reason I'm looking around for a throttle lock is to be able to let go of the handle and shake my arm around.
2005 Monster S4R
It's mostly been due to wrist position for me, not 100% effective but works most of the time.
Your '01 M900ie has the fast idle setup, if adjusted to the maximum, you can use that for a 'cruise control'.
Quote from: Speeddog on September 26, 2011, 10:29:36 AM
i'm not the only one?
i adjusted the cable so it goes up to 5000 rpm at max.  for starting, i put hold it around the middle of the lever range.  feels good man
akmnstr
Charles Darwin
Steve.In.Atlanta
I toyed around with the fast idle start in town at lower speeds and it worked!!
It's not something I want to use as cruise control per say but just enough to readjust my hand without releasing the throttle. Thanks for the tip, I think this will solve my problem.
2005 Monster S4R
hillbillypolack
Yes, it happens, and it's more about your grip than anything (duh).
A technique I use is 1) grip the handlebar like you were holding a Twinkie.  You have it in your hand, but you aren't clenching it.  Also, for more precise throttle actuation, lay your index finger on the top of the brake pivot like you were pointing.  This allows a 'base' and your throttle control is easier in turns and at low revs where the bike is snatchy.
Last detail is if you have racing gloves, don't 'over-tighten' the velcro, especially the one at the wrist.  I've found that leaving more room helps me avoid numb hands when riding.
bikepilot
If you want a throttle lock these are nice http://throttlemeister.com/
I used one on the bandit when I rode it to San Diego.
2009 XB12XT
2006 Monster 620 (wife's)
1997 TL1000S
1975 Kawasaki H1 Mach III
2000 XR650R (dez racer)
2003 KX100 (wife's)
OT
#11
Agree - you have to lose the death-grip on the throttle.
I tried the Throttle Rocker but it didn't work for me...any weight on the bars (and, hence on the rocker) meant having to fine-tune the wrist position, which is the same PIA as w/o the TR.  Because of the way it works I found myself controlling the throttle by bending my wrist up and down instead of using my fingers to 'roll' the throttle....result was more, not less, wrist pain.
Throttle Meister better as it locks throttle in a set position; but don't expect it to work like cruise control....it won't hold a set speed on roads with varying grades, just a set throttle position.
Best fix is lots of ab/core exercises.....not that I do any  ;D
imaspecialparts
I think the frequent combination of reasons for this are:
wrist is bent unnaturally, and lots of weight is being applied to wrists, so blood is limited to hand, and it goes numb.
There are solutions!
  • Adjust brake lever so that hand is in straight line, instead of bent at wrist.
  • Reduce weight on wrists by sitting more upright (perhaps add bar risers and enhance overall comfort), and squeeze tank with knees to support body.
  • Stop smoking and do not get "excited" while riding (so blood flows better to hands!)   [laugh]
Also, I have noticed I have never gotten numb hands while on the track, but I am not riding passively, unlike when stuck in traffic.
Best luck in finding comfort while riding!
IMA Special Parts - North America
Volpiano, TO, Italy - Nashville, TN, USA
IMA Special Parts designs, tests, and manufactures billet 7075 ERGAL adjustable-offset and conventional triple clamps, adjustable clipons, riser clipons, bar risers, fork damper clamps, and accessories for Ducati Motorcycles and most modern superbike
Le Pirate
I still have some bad hand numbing problems (carpal tunnel), but bar end weights...can't remember the proper term...helped me some. They soak up some of the bar vibrations that were causing me problems. Something to think about
Preisker
I get it too.   I'm getting old, that's what it is.
