1000ds FCR Build
Started by Düb Lüv, October 23, 2011, 12:00:23 PM
Düb Lüv
#181
Good. Finally stopped feeling bad about buying a lot of stuff for the build. Ca-cycle works head studs, factory pro shift arm, nicols alternator nuts. There might be a 1000ds supersport swingarm lost in the mail and praying my roadracing brake ducts aren't  subject to the same fate.
Building, building, building
Düb Lüv
#182
Quote from: Düb Lüv on October 11, 2013, 03:35:37 PM
This ones from an 848. I wanted to use as new of a sbk oil pump possible. Like a 1198, 1098, or the 848.
Started disassembling the motor again. Finally test fitted the sbk oil pump with good results.
The oil pump gear sits right in the middle of the primary gear. Perfect. More carnage pictures to come.
Düb Lüv
#183
Current status
It's almost stupid how simple these motors are.
Finally patience pays off BIG TIME.
Shark sport classic 2-1 header
Roadracing brake ducts(waited almost 3yrs for some)
Cycleworks head studs
Factory pro ceramic shifter arm(not shown)
Nicols flywheel nuts(not shown)
Well, one part I wish that could have made my list of parts was the ss1000ie swingarm I bought but was lost in the mail. Didn't loose money but just sucks.
thorn14
What's the weight savings on the sbk oil pump?
Those brake ducts are sweeeeeet.
M620 turned M800 but then back to M620 after the M800 died at 110k, and now to Multi 1000.
Nice touches.
Light is right  [thumbsup].
I havent forgotten this build.
Cheers.
Rudemouthsky
Really looking forward to this thing running. I plan to build my own SC one day and would like to use split singles. Besides sorting out the ignition it almost seems too easy...
freeclimbmtb
2011 Monster 796 ABS
Düb Lüv
#188
I finally started picking up progress. Chad at commonwealth mentioned lapping my primary gear before reinstallation. He told
Me he worked on a few bikes where the gear walked right off the crank.
Nice mating surface. Can't be too safe.
Düb Lüv
Yay! Back together. Still need to sort out my cylinder heads.
Quote from: Düb Lüv on June 07, 2014, 05:35:48 PM
I'd say so. They appear to be missing :o
someone needs to give you good head(s)
Alloy clutch drum/hub?
Düb Lüv
Quote from: koko64 on June 10, 2014, 08:56:38 PM
It's my old yoyodyne slipper clutch.
Düb Lüv
