March 29, 2024, 02:32:24 AM
FAQs and Board Policies
All about fuel tanks!
5
6
8
Topic: All about fuel tanks! (Read 224434 times)
Enjoying the ride
Re: All about gas tanks!
Reply #45 on:
May 17, 2009, 05:55:20 PM »
Quote from: ducpainter on May 17, 2009, 05:44:21 PM
Get steel....
2003 up steel will work...or an S4.
thanks ducpainter
2001cromo
Reply #46 on:
May 17, 2009, 05:59:06 PM »
Get steel....
200
+1
herm
Re: All about fuel tanks!
Reply #47 on:
May 18, 2009, 04:43:53 AM »
+2 on the steel tank, as long as you can find the right one. there are too many problems surfacing with the plastic tanks IMO.
2001cromo
Reply #48 on:
May 18, 2009, 05:21:27 AM »
Just to clarify "what the right tank for your bike" is.
(this is for any/everyone that wants to swap from their current plastic tank to a steel tank. the only exception is the testa engine Monsters as they're VERY different underneath)
Any steel tank from 2002 or newer or a 2001 S4 tank will work fine as long as you also get the fuel pump, fuel filter, gas cap ring and hinge assembly.
The tanks that will NOT directly fit are:
any carbed tank or any M900 FI tank from 2000 or 2001
Enjoying the ride
Reply #49 on:
May 18, 2009, 06:10:42 AM »
Quote from: 2001cromo on May 18, 2009, 05:21:27 AM
Thank you very mucho... Now I've seen some more ligth on Ducati...
cyclops
We all wanna be like Rose-Guy :D
Reply #50 on:
August 08, 2009, 10:24:33 AM »
Anybody know if a newer generation monster tank will fit an S2R model ?
Reply #51 on:
August 08, 2009, 01:39:10 PM »
Quote from: cyclops on August 08, 2009, 10:24:33 AM
If you mean 696/1100...
no clue.
cyclops
Reply #52 on:
August 08, 2009, 02:06:54 PM »
Quote from: ducpainter on August 08, 2009, 01:39:10 PM
no clue.
Yes thats what i mean ....
I dont care for the plastic covers, i just like the way its cut around the knees
herm
Reply #53 on:
August 09, 2009, 05:25:53 PM »
lots different about the frame.
thicker, steeper angle off the seat, attachment...
i would wager no, but WTFDIK
djrashonal
Reply #54 on:
October 29, 2009, 10:40:31 AM »
Quote from: herm (not herb) on May 06, 2008, 07:04:25 PM
Ducati Performance CF: SKU code #96922200B
From "FITS ON" link:
Fuel tank
This item fits the following models:
Monster
1000 2005, 2004
1000 Dark 2003
1000S 2005, 2004, 2003
620 2006, 2005, 2004, 2003, 2002
620 Capirex 2004
620 Dark 2006, 2005, 2004, 2003, 2002
620 Dark Single Disc 2004
620 Matrix 2004
620S 2003, 2002
750 2002
750 Dark 2002
750S 2002
800 2004
800 Dark 2003
800S 2003
900 2002
900 Dark 2002
S4 2002, 2001
S4 Fogarty 2002
S4R 2006, 2005, 2004, 2003
S4R S Testastretta 2007
So according to this, I can fit a 2002 M900 tank on my 2001 S4, Correct? That's how I read it but I wanted to be sure before I bid on one on Ebay.
01 SSSSSSS4 - Sold
'09 Triumph Bonneville
S2R800 dark - searching for
Reply #55 on:
October 29, 2009, 01:11:16 PM »
Quote from: djrashonal on October 29, 2009, 10:40:31 AM
The carbon tank is different than the steel.
I think you need an '03 or newer steel tank for the S4.
I might be wrong.
erik822
Reply #56 on:
November 01, 2009, 04:04:32 AM »
That should be correct. I have an '02 M900 and when I was looking at new tanks for it I was told an '01 S4 tank would be an direct match. They have the same gas tank internals, frame and they use the same air filter box, which determines the cutout under the tank, so it should be an exact match.
Two wheels good. Four wheels bad.
djrashonal
Reply #57 on:
November 01, 2009, 11:59:00 AM »
Great Clarifications.... Good info for all!
01 SSSSSSS4 - Sold
djrashonal
Reply #58 on:
November 14, 2009, 04:59:18 PM »
Ok, after reading through the thread I have two questions.
1) is an 07 695 tank any different than the +02 monsters?
2) is an 07 695 tank plastic like the new S*R or metal?
01 SSSSSSS4 - Sold
Enjoying the ride
Reply #59 on:
November 14, 2009, 05:16:53 PM »
Quote from: djrashonal on November 14, 2009, 04:59:18 PM
Both, plastic... As long as is not an S4RST ...It's totally different. downloaded all parts catalogs from Ducati webpage and compared tanks, S4RST, not compatible with any other except S4RST.
5
6
8
