February 02, 2025, 12:11:24 PM *
Pages: [1] 2   Go Down
Author Topic: 1999 ford explorer?  (Read 4698 times)
« on: December 15, 2011, 02:45:20 PM »
tell me what i should know
4d 4wd model with lots of options.  v6 engine.
seller wants 1500 obo..
says it needs new timing chain tensioner but otherwise good running condition.
body is fair to good.  dent on rear quarter
what's the big issue with these?  reviews say they are indestructible.
i need a haul and tow vehicle.   doesn't need to last forever.
Speedbag
And the Intrepid
Since 2004!
« Reply #1 on: December 15, 2011, 03:00:20 PM »
They are virtually indestructible. Had a 2000, most trouble-free vehicle I've had next to my '04 F150. Put gas in it, change the oil once in a while, and replace tires.
Does it have the OHC 4.0? I assume so. Some need the chain guides/tensioner when they get up there in miles.
« Reply #2 on: December 15, 2011, 03:05:01 PM »
do you know how much labour is involved?
Speedbag
And the Intrepid
Since 2004!
« Reply #3 on: December 15, 2011, 03:28:36 PM »
No, but it looks like a pain in the ass.....
« Reply #4 on: December 15, 2011, 03:38:58 PM »
its the sohc model fwiw
zarn02
« Reply #5 on: December 15, 2011, 04:34:13 PM »
My folks used to have an Explorer. I believe it was the V6. I recall it feeling quite underpowered.
(Granted, I was nineteen or twenty years old at the time...)
Langanobob
« Reply #6 on: December 15, 2011, 08:45:23 PM »
Doesn't answer your questions, but if all you need is a haul and tow vehicle and don't need to haul people, a pickup truck is a lot more useful.
How many miles on the Explorer?
ɹǝʌO d∩ uıɐןɐɹʇsn∀
Often wrong. Never in doubt.
« Reply #7 on: December 16, 2011, 02:35:18 AM »
Weird.  Coz in my part of the world they became known as the Ford Exploder...
« Last Edit: December 16, 2011, 12:11:44 PM by ungeheuer » Logged
Speedbag
And the Intrepid
Since 2004!
« Reply #8 on: December 16, 2011, 04:03:25 AM »
The pushrod 4.0 was a bit of a turd compared to the OHC version.....
« Reply #9 on: December 16, 2011, 04:53:48 AM »
well, after more research i am passing.
there is a front cam timing chain and a rear drive timing chain.  the front is a smallish job the rear requires full removal and disassembly of the engine.  i am not taking the chance...
yamifixer
« Reply #10 on: December 16, 2011, 09:22:59 AM »
I had a Mazda Navajo (same creature with differend grill) It was great up till the end. then is became the hellish beast of song and story. in the last 6 months I Had to do the following:
1. Rebuild the front axle
2. repair the transfer case shift motor (PITA)
3. replace transfer case
4. put in 2 fuel pressure regulators
5. replace fuel pump
6. It ate front brakes like a snack food.
7. when the tranny started to slip i admitted defeat and traded it in on a Tacoma.
I like to think I am not hard on vehicles and am over the top on maintenance but after 110000 miles it started to fall apart.
Valve Springs are EVIL
Speedbag
And the Intrepid
Since 2004!
« Reply #11 on: December 16, 2011, 11:27:27 AM »
Apparently I got lucky.....I traded it off around 100K and wondered if I shouldn't be keeping it longer.
Porsche Monkey
JuddDdd likes my
The DMFer formerly known as Ducaholic
« Reply #12 on: December 17, 2011, 09:48:06 PM »
If they ever overheat the heads are toast. Other than that pretty solid imo.
« Reply #13 on: December 18, 2011, 06:13:21 PM »
4 our of 5 of our custodians at my workplace have that generation of explorer.  The 5th one's g/f has a Mercury Mountaineer of the same generation.  All are high mileage with minimal repairs needed because of decent to good normal maintenance.  The Mountaineer got the driveshaft U-joints replaced after  200,000 miles and it's going strong.
JM
The Bacon Junkie
I have a Bacon Wrapped
Save the brass...
« Reply #14 on: December 18, 2011, 06:24:45 PM »
My '02 Nissan Frontier hit 200,000 miles, then I drove it cross country.
Only thing besides oil and tires that I've had to replace was the timing belt last year and a valve cover gasket this year.  Oh yeah, replaced the front brake rotors two weeks ago... They bang head were the originals!   Shocked
It still has the original clutch...
I only changed the oil when I remembered to, and that's about all I ever did to it.   Roll Eyes
I'd get another one, without question...   [
bacon
Save the Brass...
Pages: [1] 2   Go Up
