984cc kit (Sanguinario Demone)
Started by avizpls, January 11, 2012, 04:50:52 PM
AdmiralKit
ST2 cams are damned hard to come by, but one of our forum members is selling his M900ie cams if you're willing to go down slightly:
http://www.ducatimonsterforum.org/index.php?topic=54206.0
PM 'Cloner'.  He's got a set of ST2 cams & valves he'll b parting with very shortly...
avizpls
Done!  [evil]
So now we're talking!
Crankshaft light, knife, balanced
Carrillo rods
96mm pistons and cylinders
ST2 cams  [drink]
FCR41 duals. (might make some short stacks if possible...we'll see)
then next year I'll get the MBP head work done.
#11
avizpls
I think I'll also cut out the frame behind the suspension mounts, and build a bolt-on Al subframe for the 996 tail section im running.
This is gonna be a fun track season.
#11
The Mad King Pepe'
Hope this may be useful for you:
Quote from: MotoCreations on September 06, 2010, 09:07:00 AM
FYI -- 984's run VERY hot due to thin cylinder walls.  Needed two oil coolers to keep my Supersport w/FCR's from getting too hot with the fairings installed.  I was running a 984 in my DesmoDevil w/ST2 cams and FCR's without oil coolers and 100% synthetic.  Tens of thousands of miles on it over the years but it was very sensitive to the outside heat environment. (great engine to ride though in the cold!)  It's DOA now -- cylinders scored, broken piston rings, piston damage from detonation and bearings "cooked". New engine transplant upcoming is less "hooligan"...
Good luck with the build! [thumbsup]
monstermick58
Interesting project, I too have been offered the same kit but not knowing what should be done to complement it is keeping me away from it but, I will watch with more than a passing curiosity.
[popcorn] [popcorn]
                                          Mmick
avizpls
Well I'll let you know how it works out. I have the machining done and all of the parts...just need time to put it all together. Thanks to cloner for the cams!
#11
avizpls
#11
Fancy...
How's it run? [evil]
monstermick58
Quote from: avizpls on March 08, 2012, 04:14:06 PM
Dudes...
SWEET!!
   Will your finger print stay on the crank??
                               Mmick (an unabashed bumpy)
Rob Hilding
avizpls
Nt quite sure how it runs just yet haha. My biggest concern right now is the tuning. I got the FCR kit from cacycles, but it will be optimized for a more basic setup. Wonder how far off it will be?
#11
Quote from: avizpls on March 10, 2012, 10:55:55 PM
My understanding is it will depend on head work performed and compression more than just displacement.
It will be better than stock carbs, but no one can say where you'll end up with tuning.
Good luck with that. Do you have access to dino time
avizpls
Yes, I do. It won't be free, but affordable.
#11
