removing magnet basket from flywheel?
Started by Privateer, March 28, 2012, 07:26:32 PM
Privateer
04 620, 49,009m
I had the opportunity to pull my side cover off today and when I did there's lots of oily crap inside the clutch slave.
the push rod o-rings are new'ish, and this is the second set I've gone through in the last 43k miles.
normally I'd just replace the orings, but this seems to be a recurring thing now and I'm not sure what the problem is.
any ideas or suggestions?
sofadriver
seems like you need some "new-er'ish" o-rings  ;)
Mike in Tacoma
'08 S2r 1000 - Red on Red
'96 900 SS/SP
IBA 38181
Privateer
Quote from: sofadriver on March 28, 2012, 09:28:40 PM
yeah, I'd think so too, but seems to be a recurring problem and I'm just putting a band aid on it.
the last set I put on in September 2011, around 5,000 miles ago.. seems kind of soon to me.
Stiction in the pressure plate bearing could spin the push rod and take out the o rings and even later spin the slave piston, taking it out.
brad black
Brad The Bike Boy
http://www.bikeboy.org
jgrm1
I've wondered why the fluid quickly turns dark in the clutch reservoir on my S2R1000 and other Ducatis.  I just did a fluid change and it is already turning.  Is there a relationship here?
-Jeff
BMW:  2016 R1200RS, 2000 R1100S, 1975 R90S
Ducati:  2008 S2R1000, 1998 900 Supersport Final Edition
Norton:  1974 Commando 850
Triumph:  2016 Thruxton R, 1971 T120R
Privateer
Quote from: brad black on March 29, 2012, 02:56:22 AM
is it oil or brake fluid?
it looks like oil to me and my clutch fluid is almost brand new.  Of course I don't really have a way to distinguish oil from dirty clutch fluid.
Quote from: koko64 on March 28, 2012, 09:58:35 PM
hmm i was wondering about that last night.  I'm not worried about the slave piston, it has a bearing to manage the spin.  I guess I'll be pulling off both sides now.
Quote from: Privateer on March 29, 2012, 06:23:10 AM
There's an easy way - brown paper bag. Get some of that fluid on it. Oil will be.. oily turning the paper translucent and won't evaporate. Brake fluid will be more like water.
Privateer
Quote from: Sad Panda on March 29, 2012, 08:05:51 AM
good tip, thank you.
I ordered a ca cycleworks gasket today, i'm going to pull the clutch cover when it shows up and check the throw out bearing for good measure.
discovered a leaking fork seal too.  not my week for motorcycles apparently.  40k miles seems to be, for me, when stuff starts to fail.
taste it... ;D
Privateer
since I'll have the clutch side cover off, when is a good time to replace the clutch pack?
I don't feel it slipping, but I envision it being a boiled frog kind of thing.
Is there something to look for that will indicate it's due to replace?
Steels not scored or blue?  They are still good.  There is a spec on friction disk thickness, off hand I don't know what it is, I will look it up later.  ^ speed or 5 speed?
Over 60K on my original clutch , so don't be surprised if all is well.
Howie, his 620 is a 6-speed.
Parts manual says it's an APTC clutch.
There is a minimum thickness spec on the plates.
OEM plates are the best replacements I've found.
APTC plates are different from the early 'standard' plates.
Privateer
Quote from: Speeddog on March 30, 2012, 09:27:02 AM
thank you nick and howie.
I was at the dealer getting crush washers last night.  The throwout bearing is ~$55 and the clutch pack is ~$360 so I'll need to wait for another paycheck on that one.
Privateer
well that didn't work.
Only getting 9v at the battery.  Jumped off my car to get it running, tried to check the voltage at the stator and the connector was hot with a scorch mark.  Too frustrated to work on it more, so I'll have to try again tomorrow, see what kind of voltage the stator is putting out.   really really hoping I didn't fry the stator again.
/sigh
