November 26, 2024, 06:20:11 PM *
Author Topic: Slip-on vs full exhuast systems  (Read 1591 times)
chaldoking
« on: May 04, 2012, 05:33:42 AM »
I have a 2011 monster 796 and was wanting to upgrade my exhaust system. I was wondering if there was a big difference in performance from a full exhaust system vs a slip-on? Is the performance in the full exhaust system worth that extra $ grand or two?
Scoober1103
Good morning my
« Reply #1 on: May 08, 2012, 04:17:25 PM »
I have a 2009 M1100 which had SC Project slip on cans when I bought it but everything else stock. On the weekend I fitted a DP ecu from a Termi slip on kit which I picked up cheap off fleabay here in OZ and after consulting with Ducati in Brisbane I bought and installed a K&N air filter which I was advised is the closest match to the DP filter which also comes with the Termi kit but difficult to get by itself!
The end result was an amazing difference in the way the bike rides, allot easier to ride at slow speeds and a noticeable performance increase with better throttle response. Also allot less popping and burbling from the pipes when decelerating. I pulled the plugs after around 100 km on Sunday and it appears to be running perfectly, no signs of running lean or too rich. I will be getting it to a shop for a check over (emissions and tune) when I can but incredibly happy with the end result!  Wink
For now it's a new bike and down the track I will be thinking of re-flashing my standard ecu and further upgrades.
I know it's a little different but my findings from a slip-on kit!
Cheers,
Scott
09 M1100 + stuff.
07 GSXR750 stock as a......
15 KTM Freeride 250r for hurting myself!
Don't buy cheap shit, it can cut your balls off.
wannabfast
« Reply #2 on: May 08, 2012, 04:23:34 PM »
the only real benefit of getting a full system is looks and pipe routing is changed, depending on the system it might remove the flapper valve
but most of the restriction in teh stock 796 exhaust is in the stock cans, so a slip-on would be a good bang for your buck
Howellerman
« Reply #3 on: May 09, 2012, 03:52:22 PM »
+1 on Scott's reply: the DP ECU  made a huge difference. I can troll city streets as low as 3K, and the increase in mid-range power is phenomenal - hammer blows, big freakin' hammer blows on those pistons! The only issue I had is that goes to KPH versus MPH, but a Speedo Healer fixed that.
« Reply #4 on: May 09, 2012, 04:46:58 PM »
You should be able to switch that in the gauge cluster....
« Reply #5 on: May 09, 2012, 09:30:30 PM »
yeah that was a useless purchase, the new monster gauges are simple setting switches. check out your manual
Howellerman
« Reply #6 on: May 10, 2012, 03:19:50 PM »
In that light, yes. However, the instructions that came with the Termi's said nothing about converting from KPH and MPH (they were poorly Xeroxed pages, for shits sake!), and I still had a +10-percent high speedo reading. Besides, the cost of the Speedo Healer was under the standard Ducati add-on uplift of $250...    Grin
« Reply #7 on: May 10, 2012, 03:32:07 PM »
 laughingdp laughingdp laughingdp
Too true. Too true.
