Feedback on Ducati Designs light upgrades
Started by d3vi@nt, June 10, 2012, 07:53:21 AM
d3vi@nt
I'm looking at the LED turn signal and brake light upgrades from Ducat Designs for my ST2: http://www.ducatidesigns.com/headlight_upgrades?b=1
Does anyone have any thoughts, knowledge, experience, etc. to share on these? Better alternatives?
'13 MTS GT
'99 ST2
'07 M695 - Sold
zooom
Paul's stuff is solid!....his headlight set-up for those bikes is an immensely valued upgrade!
2010 KTM 990 SM-T
Click the webBikeWorld link on that page and scoll to the bottom. The before and after photos of the light beam, and strength say it all.
d3vi@nt
Quote from: Slide Panda on June 11, 2012, 07:49:00 AM
Right -the headlight gets rave reviews, but I'll have to save my pennies for that upgrade. I'm more interested in the turn signals and brake lights. Don't know if the LEDs draw more power, how much longer they last, how much brighter they are, etc.
Thanks for the replies, though.
'13 MTS GT
'99 ST2
'07 M695 - Sold
zooom
Quote from: D3vi@nt on June 11, 2012, 08:12:27 PM
generally speaking for a moment...
LED's draw less power, last a lot longer than incandescent bulbs, and if set up in a proper array/format/structure, can be a lot brighter....
now specifically speaking to DD and their products for a moment...
Paul wouldn't put a product out there for nothing just to make a buck...he believes in what he put out there because he used it himself on his bike....so take that for what it is worth.
2010 KTM 990 SM-T
Yeah in hand waiving terms LEDs are better - but take more craft and a burning blub - and don't get sold on the idea that LED replacements for the stock bulbs are better though. WebBikeWorld has tested a ton of LED things that are designed to replace incandescent bulbs with no mods - basically bulb or disc shapes with LEDs on them. Those things, to a man, under perform and cost more side by side to a regular bulb.
But, if you get a purpose built LED unit, now that can be a step up. I have a Mk. II Super Nova from Vizi-tec
http://www.vizi-tec.com/products/ducati_supanova.html
No cheap, but the maker is a member here and know's his business. High powered LEDs that a running at low loads for longer life, a heat sink and fans (freakin' fans!) to ensure cooler operation for longer life and PLENTY of light output. The Mk. II is actaully adjustable at power on, with 3 brightness levels. Country road, normal, and OMG LAZERS!
For the turn signals - just be aware that you'll need to replace the blinker relay or add in some resistors and do some other fiddling depending on the configuration of your wiring. Adding (4) leds to my 620 caused the common rapid flash that folks get - solved with resistors. Adding them to my '00 900 with it's different relay and dash resulted in all 4 lights coming on and staying that way initially. There wasn't enough resistance to get the older type relay to click back to off, and the blinkers share part of the circuit through the dash.
So I used a solid state electronic relay to get the blink back, and had to rewire the dash a little to resolve the 4 way light matter. It was an easy job, and about $5 of crap from radio shack (couple diodes and shrink tube) - but it does require one to get into the dash and be comfortable altering the wiring.
c1fer
Read this thread for LED Turn Signal mods.
You either do some basic wiring, or change the Blinker relay from Analog to Digital.
Quote from: carbmon on August 12, 2012, 09:04:28 PM
You could forget all the hassle of heat-generating / power-robbing resistors and just install a blinker that works with LEDS.
I've been able to get one for all my bikes swapped to LED turns that works correctly and is a direct pin-match from the selection at www.superbrightleds.com (click the link to go directly to the LED-compatible flasher spec page on that site).
