February 23, 2025, 09:26:08 PM *
Pages: [1] 2 3 ... 5   Go Down
Author Topic: Titanium Axles and stuff  (Read 15566 times)
« on: August 21, 2012, 05:15:44 PM »
Hi All
Want a Ti or superduper alloy axle for your Monster?
REAR AXLE: Just letting you all know that I have sent an axle from a 900 Monster with alloy swingarm to Monsterlover (Kevin) at South Morgan Technologies. Looking to have Ti or the latest alloy axles made. If you have a 900 Monster with alloy swingarm and want to be in on the production run then you can PM me or Kevin. Kevin said he can do the axle nuts too if you want. The more the better for all of us including Kevin.
Will have an initial price soon to give you a ballpark figure.
FRONT AXLE: I also sent an M900 17mm front axle to him if anyone wants a Ti or alloy copy made. That is the ancient Monster axle, so f you want a later type axle then Kevin will need a sample sent to him.
Kevin is a sponsor and member. Payments are straight to Kevin, I'm not a middleman and don't get a cut. I just want a reliable supplier of quality machined parts and have it on good authority that he is just that.
Cheers
Tony
« Last Edit: August 21, 2012, 07:18:08 PM by koko64 » Logged
« Reply #1 on: August 22, 2012, 11:18:28 PM »
Get your fancy axles here!
Join the production run.
Craftsmanship, ladies and gentlemen. Grin
Omnipotent Potentate
Personal Pretext
« Reply #2 on: August 23, 2012, 04:20:21 AM »
Mmm? What's the details? I've got a '00 900
« Reply #3 on: August 23, 2012, 04:41:40 AM »
 If its an alloy swingarm with the gold adjustment plates then it matches. The front of course is another matter. Theres no reason he cant help you there if he gets a sample.
Kevin is waiting for enough orders to do a production run. He is getting a price on different materials.  Pm him or myself if you like.
Personal Pretext
« Reply #4 on: August 23, 2012, 04:44:58 AM »
Alloy? It's the Aluminum swinger on the S - vs steel. Though I don't thing the axles are different - just the side plates.
carbmon
« Reply #5 on: August 23, 2012, 06:13:11 AM »
Regarding the REAR axle - I've been researching this while talking with Tony and Kevin about the project; I have both aluminum and steel swingarms in hand for measurement; the following may be useful:
Starting with the given that this is for 17mm diameter axle models ....
The inside dimension of the aluminum swingarm (between the 'forks') is the same as steel.  However, the outside dimension is greater on the aluminum arm because of the thicker wall of the 'fork' extrusion in aluminum.
So, the aluminum swingarm has a LONGER axle than the steel model to account for this.  An axle for the steel swingarm is not long enough to properly capture the nuts if used on an aluminum arm; an axle for the aluminum swingarm is too long in the unthreaded section to allow the nuts to grip on a steel swingarm.
I believe that the Ducati Part Number for the axle that Kevin is replicating is 81910241A.
HTH  waytogo
« Last Edit: August 23, 2012, 06:16:57 AM by carbmon » Logged
2001 M750 Monster - for quick therapy
2004 ZG/GTR1000 Concours - for sale
2012 DL650 Wee Strom - my first fuel injected / ABS bike!
1981 R100RS - long hauler emeritus (retired)
++ with thanks to Daniel Bernoulli, (almost) all my bikes have carbs ++
Personal Pretext
« Reply #6 on: August 23, 2012, 06:19:32 AM »
Good to know!
carbmon
« Reply #7 on: August 27, 2012, 05:11:12 PM »
Kevin or Tony - any update on materials/pricing ?
The best kind of whore is a
« Reply #8 on: August 27, 2012, 05:16:18 PM »
Glad you reminded me. I'm working second shift this week. Ill measure that axle now and email fo a quote on material.
« Reply #9 on: August 27, 2012, 06:14:22 PM »
So, if I have this right, 2 of you want rear axles and one of you wants the bastard sized front axle?
I got the rear measured up.  The center hole was drilled during the manufacturing process and they drilled it half way from each end.  The holes do not line up laughingdp
I would like to use tubing if possible as it would save a lot of money in tooling.  A good drill to do that right is probably $400.  I could use a cheap hss drill but then you get a crappy hole that doesn't necessarily go straight.
** on second thought, I don't like the tubing idea as much.  Looks like 3al-2.5v is easy to get in tubing, but it's not nearly as strong as 6al-4v, which I can get in a solid.**
These Ti axles will probably be a lot cheaper than you guys think. . .
Biggest thing right now - How many people are in?  More people = lower cost per piece for material.  Let's just go with a ball park price of $150 shipped as a target (which may change up or down some)
« Reply #10 on: August 27, 2012, 07:19:55 PM »
I'll have a rear axle and a Jurassic front axle please Cheesy
So far we have interest from carbmon, SP, junior varsity, BastardHK and myself. I'll see if a mate also wants a Jurassic front.
Who wants to confirm firm orders?
Price smashes TPO
Made by a forum member
He's a craftsman
He's a good bloke
He has an awesome avatar
C'mon sign up!
« Last Edit: August 27, 2012, 08:51:05 PM by koko64 » Logged
carbmon
« Reply #11 on: August 27, 2012, 10:04:07 PM »
Per email to Kevin, I'm just waiting for unthreaded & total length for the rear to confirm it fits my swingarm.  If that's right for me I'll commit  waytogo
Then I've got to ask the price for the matching flange nuts, drilled for safety wire per race tech rules?
« Last Edit: August 27, 2012, 10:19:50 PM by carbmon » Logged
« Reply #12 on: August 27, 2012, 10:59:33 PM »
Make that two Jurassic fronts, one Monster rear and an SS/Superlight rear!
« Reply #13 on: August 28, 2012, 03:17:37 AM »
Wish I had a spare $150 laying around.
My bike is set up with the silly front axle too.
« Reply #14 on: August 28, 2012, 04:11:35 AM »
I got no cash for it, business card. It's a legit business expense! Gotta showcase the product of my new supplier! Grin
Pages: [1] 2 3 ... 5   Go Up
