Factory dry clutch pressure plate question
Started by Scoober1103, September 12, 2012, 01:03:30 AM
Scoober1103
Hey DMFers, I pulled the dry clutch out of my M1100 (9000km) to service, clean and check the plates and bearings and noticed the standard cast alloy pressure plate had a few holes at the outer edge of where the springs seat!
It appears to be a flaw in the casting rather then being warn through and they aren't cracks but not totally sure. As it is the only one I have seen thought I would consult the greater monster community!
Is it time (justification) for a new billet plate, collars, springs and cover? [evil]
Or is this common with the factory pressure plates?
Thanks in advance for any info and help on this.
Cheers,
Scott
09 M1100 + stuff.
07 GSXR750 stock as a......
15 KTM Freeride 250r for hurting myself!
Quote from: koko64 on April 02, 2014, 02:52:23 AM
Don't buy cheap shit, it can cut your balls off.
To be on the safe side (foolproof keyword: safety) I suggest getting an open cover and fancy new pressure plate ;D
Scoober1103
Thanks Tony and Stop, I was uncertain but might er on the safe side.... [laugh]
Cheers
09 M1100 + stuff.
Quote from: koko64 on September 12, 2012, 02:32:02 AM
I'm sorry I have terrible news..
I'ts normal. ;D
I'd use the word typical.
Normal infers that it's right... ;D
 [laugh] True.
Seriously, the oem pressure plate is lighter than many fancy looking aftermarket ones. I would only consider a replacement if it was  significantly lighter and improved clutch function. I put my money into better springs, and light plates, basket and drum. I have dropped 1.69 kgs of rotating mass. (Edit: I have the lightweight Vee Two steel basket).
The oem pressure plate got VHT hi temp engine enamel.
Spose I'm a heretic. ;)
Scoober1103
Quote from: koko64 on September 12, 2012, 04:25:01 AM
[laugh] True.
Seriously, the oem pressure plate is lighter than many fancy looking aftermarket ones. I would only consider a replacement if it was  significantly lighter and improved clutch function. I put my money into better springs, and light plates, basket and drum. I have dropped about 1.8 kgs of rotating mass. The oem pressure plate got VHT hi temp engine enamel.
That's a valid point too, have plenty of other things I could be doing but the springs and collars certainly need a pretty up as rust wasn't a good look!
Thanks again guys!
09 M1100 + stuff.
Scoober1103
Just out of curiosity I weighed my stock cast pressure plate and with the bearing installed it runs at 292g! One brand of billet plate advertised claimed a weight of 284g with bearing and I noticed it was pretty heavily machined with lots of cut outs and ventilation!
09 M1100 + stuff.
What's that 6g gonna cost?
Skip a beer mate and save 2-300 hundred. ;)
Quote from: ducpainter on September 15, 2012, 04:33:31 PM
What the hell kind of advice is that?
Skip beer AND bling opportunities  [bang]
;D
Quote from: stopintime on September 15, 2012, 04:36:11 PM
;D
I'm sorry...
I'm sober.  :P
Scoober1103
Yep I will remain in the minority and keep the stock one!
Skipping beer is not an option!  ;D
09 M1100 + stuff.
the point of those heavier ones is to protect the clutch post more than anything else. replacing drums aint fun. :-X
Quote from: He Man on September 15, 2012, 05:19:04 PM
I don't think any pressure plate protects the clutch hub.
You must mean a heavy cover.
