February 24, 2025, 02:54:22 AM *
Pages: [1] 2   Go Down
Author Topic: DP Lightweight Flywheel‎ question  (Read 2115 times)
lillo
« on: November 15, 2012, 07:05:37 PM »
I am new to modding and such on bikes. What exactly is a Lightweight Flywheel‎? What does it do  and how do you install? Thanks guys
m696: full termi kit; works fender eliminator; Rizoma; crg bar end mirrors, alarm system; ducati corse decals; blackened heat shield covers;
848 evo: rizoma
Feral 859
« Reply #1 on: November 15, 2012, 08:16:24 PM »
http://www.ducatimonsterforum.org/index.php?topic=46983.msg852985#msg852985
lillo
« Reply #2 on: November 15, 2012, 09:23:23 PM »
okay thanks that helped but how would you install one and do you recommend putting one in?
848 evo: rizoma
Feral 859
« Reply #3 on: November 15, 2012, 09:36:03 PM »
I recommend lightening a stock one, but folks will have different opinions.
http://www.ehow.com/way_6183879_motorcycle-flywheel-removal.html
lillo
« Reply #4 on: November 15, 2012, 10:15:07 PM »
its something that I might consider doing myself if possible but I need to find some video or pictorial instructions on how to do it.
848 evo: rizoma
Feral 859
« Reply #5 on: November 15, 2012, 10:27:43 PM »
Google  Cheesy
lillo
« Reply #6 on: November 15, 2012, 11:00:25 PM »
 waytogo i found some guides- does not look very easy to do though...
848 evo: rizoma
Feral 859
« Reply #7 on: November 15, 2012, 11:03:00 PM »
Well it's not like changing out a light bulb for sure.  Cheesy
Dirty Duc
I'd rather be an anti-
« Reply #8 on: November 15, 2012, 11:03:11 PM »
Depends on your definition of easy... Wink
Have you changed the clutch on a car or a BMW bike?  If you can do that, anything on a Duc is pretty easy and just a matter of torque values and details.
lillo
« Reply #9 on: November 15, 2012, 11:23:48 PM »
nope never had any experience with clutch work, but I would like to learn (I love mechanics)- I probably should buy some sort of Ducati DIY manual.
848 evo: rizoma
« Reply #10 on: November 16, 2012, 12:01:16 AM »
expensive tools
Dirty Duc
« Reply #11 on: November 16, 2012, 06:11:34 AM »
LT Snyder is probably the most approachable DIY publisher.
herm
« Reply #12 on: November 16, 2012, 06:15:01 AM »
I recently had a stock flywheel lightened by a member of the board, who did an incredible job. And, because I cant afford to fix big mistakes, I had a Ducati mechanic install it.
I was/am extremely pleased with the changes to the ride. One thing I have found, however, is that my bike will sometimes stall at idle. I think this has something to do with the reduced mass of the flywheel not having enough inertia....and it can be corrected...when I get around to it.
« Reply #13 on: November 16, 2012, 06:34:02 AM »
you have to adjust your idle just a bit higher.
for my 696
stock idle is 1200rpm
with the ergal flywheel I have it set at 1300rpm and have no stalling issues.
and it's a dream to downshift and match revs  Dolph
lillo
« Reply #14 on: November 16, 2012, 09:34:28 AM »
Well it sounds like you guys are pleased with the results and I definitely like the fact that "it's a dream to downshift and match revs". Since I do not have all the necessary tools to install one and set the idle to 1300rpm I will have to first buy one or like you said Herm have the stock one lightened and then bring it in to the dealer.
848 evo: rizoma
Pages: [1] 2   Go Up
