January 06, 2025, 05:02:13 PM
Team UnorthoDUX Ducati based land-speed racers New pic pg 19!
17
18
19
20
36
Topic: Team UnorthoDUX Ducati based land-speed racers New pic pg 19! (Read 226161 times)
Re: Team UnorthoDUX Ducati based land-speed racers New pics pg 11
Reply #255 on:
September 10, 2014, 01:50:32 PM »
You're using 2-stroke reed valve assemblies on the compressor, so you get 2 compressor strokes for each (power cylinder) intake stroke?
Dirty Duc
I'd rather be an anti-
Reply #256 on:
September 10, 2014, 01:53:43 PM »
Quote from: Speeddog on September 10, 2014, 01:50:32 PM
Yes. There's plenty of boost available, but it adds a lot of heat to the charge. A power-limiting amount of heat.
Ducatis on the Salt
Reply #257 on:
September 11, 2014, 01:13:58 PM »
Motor is an '03 DS1000 with unknown mileage but seems to run well. Front end is an '01-'03 GSXR600 unit b/c it was cheap and is the same that the 749LSR runs (to keep parts the same between the bikes).
Due to work and other life-demanding BS, I was completely unable to lend a hand this year. That will NOT be the case in '15...
There is also talk of a 3rd Team UnorthoDUX bike. This time in a Monster frame...
Reply #258 on:
September 11, 2014, 01:45:21 PM »
Quote from: Dirty Duc on September 10, 2014, 01:53:43 PM
Is the blowoff valve opening?
Dirty Duc
Re: Team UnorthoDUX Ducati based land-speed racers New pic pg 17
Reply #259 on:
September 11, 2014, 02:00:16 PM »
Quote from: Speeddog on September 11, 2014, 01:45:21 PM
Yes.
It's managing the boost properly, but either the design of the blower or the amount of boost is really demanding. With the "little" spring, it just doesn't make power (~66mph on the last day). The first pass was "big" spring only with fixed advance and the wrong dwell. With both springs, MAT was about 200 degrees at idle, and went up from there (~80mph passes in between first and last).
Results at
www.saltflats.com
Ducatis on the Salt
Reply #260 on:
September 11, 2014, 02:19:36 PM »
We need to talk about your blower system.
What bike configuration set the existing record?
Dirty Duc
Reply #261 on:
September 11, 2014, 02:34:46 PM »
http://bikesbuiltbetter.com/about/foil_hat_racing.php
Looks like a turbocharged VFR500.
Last Edit: September 11, 2014, 02:50:01 PM by Dirty Duc
Ducatis on the Salt
Reply #262 on:
September 11, 2014, 02:52:30 PM »
Quote from: Dirty Duc on September 11, 2014, 02:34:46 PM
Are they still running on the salt?
Dirty Duc
Reply #263 on:
September 11, 2014, 03:07:06 PM »
They're not in the Speedweek program, and I didn't see them in the World of Speed entry list.
I didn't actually look for the team until you just asked the question. I was pretty sure they weren't doing what I was doing, so it didn't seem relevant.
Ducatis on the Salt
Reply #264 on:
September 11, 2014, 03:14:51 PM »
Give me a call when you've got some time to talk.
Dirty Duc
Reply #265 on:
February 15, 2015, 09:52:33 PM »
This may have been part of the problem...
Ducatis on the Salt
Dirty Duc
Reply #266 on:
February 23, 2015, 08:06:13 PM »
So, an update to the plan for this year.
4960 - Single Supercharger gets a new blower head and some fiddling work like a new gas tank that doesn't get in the way of laying down, new exhaust, some lowering and some other bits. And goes to methanol.
7490 - 749LSR gets new exhaust, some bodywork, and a few tweaks I'm calling part of the learning curve. And goes to methanol.
Ducatis on the Salt
Dirty Duc
Reply #267 on:
March 19, 2015, 08:02:59 PM »
Ducatis on the Salt
Reply #268 on:
March 20, 2015, 06:13:31 AM »
Hello Mr. Minimized-frontal-area!
Damn do I want to ride that thing on the salt....
Dirty Duc
Re: Team UnorthoDUX Ducati based land-speed racers New pic pg 18!
Reply #269 on:
March 23, 2015, 08:41:54 PM »
You can ride it on the salt... you can also ride it on what I'll call my "test track"
Ducatis on the Salt
17
18
19
20
36
