Another valve thread. Mine are make the beast with two backsed...
Started by memper, February 25, 2013, 12:42:26 PM
memper
Decided to examine my valve clearances today. All the openers were so tight I could barely get the 0015 in there. The closers were all about 005-006 (loaded gap). This can be mended I'm sure.
BUT the scary question: Is there supposed to be oil under the covers?? I suspect not. Horizontal cover unleashed a stunning 1 Tbsp of oil on the exhaust side. The vertical cover let loose about 1/4 tsp on the exhaust side.
Are my valves on the exhaust sides so loose that they are letting tons of oil by? Or are my valves cooked and I need new ones?
Plugs were a bit oily on the top ring as well. Ceramic looked perfect though.
brad black
Brad The Bike Boy
http://www.bikeboy.org
memper
Quote from: brad black on February 25, 2013, 01:21:59 PM
tis the season of premature speculation it seems.
Im new to desmo valves and even valve adjustments period.
Has there been a rash of premature speculation lately?
Thanks fellas.
Ddan
P'raps some sort of instructional manual would be helpful   ;)
Ducati Monster Forum at
www.ducatimonsterforum.org
memper
Quote from: Raux on February 25, 2013, 01:38:03 PM
oil in the heads is better than oil in the cylinders ;)
Right, but there was some on the plugs. But could this be resolved with a properly adjusted set of valves?
Quote from: memper on February 25, 2013, 03:31:34 PM
Oil or fuel?
memper
Quote from: memper on February 26, 2013, 03:39:40 AM
Black n shiny on the top ring. Maybe down one thread aswell.
Top ring?
Black and shiny could be either.
memper
I suppose it could also be gas soaked carbon...
Wiped off pretty easy with a cloth.
I guess I will assess the valve clearance issue first, then move on.
So about my clearance issue, I gotta order four larger shims for the closers and sand down the four openers, yes?
Quote from: memper on February 26, 2013, 04:37:11 AM
Stop trying to diagnose a problem...if there even is one...with valves that are way out of adjustment.
Start with the basics. Until you have a baseline all the speculation and worry is wasted energy.
memper
Agreed.
I found this shop: http://www.emsduc.com/products.html
I can't afford the full shim kit. Glad to see they sell individual shims.
But what size do I need for my 99 750?
Quote from: memper on February 26, 2013, 05:20:49 AM
Agreed.
Keep in mind you need to use his measuring adapter to get closing shims that will work. You also might want to order a size on either side of the ones you think you need to account for differences in measuring equipment. Be prepared to sand shims.
You have 8mm stems.
