November 26, 2024, 10:41:03 PM
OZ monsters
Questions about roadworthy check in QLD
Topic: Questions about roadworthy check in QLD (Read 2026 times)
NFG
Newb
May 20, 2013, 09:28:10 PM »
I'm looking to sell my beloved 1993 M900, and I took it to a local shop to see about a roadworthy on it, so I could get the sale process started. The mechanic took one look at it and rattled off a bunch of stuff that would fail the bike, including a few that were on the bike when I bought it from the dealer.
Specifically, he said the blue-tinted headlight would fail, and the Termi pipes (he kept calling it an 'exhaust bung' but maybe this is an Australian thing or my own ignorance, I have no idea what that is, but he said specifically that Termi pipes would fail). He said the seat has some cracks in it (the cover is stretched at one point), so that needs to be fixed, there was metal showing through rubber on a foot peg, so that would fail. All the discs would fail (
Where can I verify the required widths? Is 3.49mm too thin on the back?
) Front sprocket would fail (and would have to be replaced along with the rear, even though the rear is only a year or so old).
Does all this ring true? He basically suggested I let the rego lapse and sell it 'as is' because fixing it all would be (ballpark) $2500, which is half what I was hoping I could get for the bike.
So yeah, my first bike sale and it's sort of hit a snag. Any advice and/or confirmation would be appreciated.
UPDATE: yeah, the discs are too thin (I found the user's manual). Some of the other things seem a little bit aggressive: the seat, for example. According to what I've found, a seat can fail if it has structural issues, sharp edges etc. Stretch marks shouldn't fail, if I'm reading this right.
Last Edit: May 20, 2013, 09:50:05 PM by NFG
FIFO
Doing the latter
Re: Questions about roadworthy check in QLD
May 21, 2013, 12:05:18 AM »
Tell him he is dreaming $2500
If your handy on the spanners,
Chinese brake rotor on eBay front/rear should be no more than $300 and go up from there for name brand,or used.
If the seat cover looks Dodgy get it recovered anyway, shouldn't be to expensive, Will help sell the bike.
The head light probaby just has a plastic tint on it, peal it off?
Billet footpegs on eBay from $40.
With the Termis, i think he means baffles not bungs, that go in the end off the zaust should quiet it enough to pass. though baffles might be hard to find
some one might lend you some sock cans to get it passed
Second hand stock mufflers usually go cheap on eBay.
Some on there now from a forum member
http://www.ebay.com.au/itm/Ducati-Monster-OEM-L-R-Standard-Remus-Muffler-/281108688145?pt=AU_Motorcycle_Parts_Accessories&hash=item4173622d11
Not sure in QLD.
I would fix the obvious,Noisy zaust a priority, head light lense, seat, foot, pegs ,a good clean and degrease, look like you tried to do a bit.
Leave the rotors and go some were else, for the inspection
loony888
"I WAS GOING HOW FAST, OFFICER?"
May 21, 2013, 02:23:19 AM »
rob's advice is spot on, i'm fairly sure you can buy new footpeg rubbers to replace your worn ones, to recover the seat go to john moorhouse, google "ergo seats" for his details, he's very good and not expensive at all. Aftermarket rotors are quite cheap, did you get the roadworthy started with paperwork? cause if you did you can't take it elsewhere until he completes the 2nd inspection whether it's a pass or fail. If he didn't get started find another place to get it done but thank him for pointing out the obvious fails, which they are, unfortunately.
HERE AND NOW 12 DIAVEL AMG
93 888 RS
09 1098R BAYLISS
07 Husqvarna TE 450
GONE BUT NOT FORGOTTEN 03 S4R 95 900SL
01 S4 93 900M
96 748SP
Betty
May 21, 2013, 11:10:39 AM »
Of course Rob is right about the alternatives, but to be fair you could spend $2,500 on that stuff ... with the exhaust the big question mark.
Most rotors are $600+ for the pair - new pads add up too, new headlight a couple of hundred, ditto seat, if you replace the chain with the sprockets - another couple of hundred, new stock exhausts probably cost a couple of thou on their own (but that is obviously not the best option) ... haven't even considered labour yet.
So you can take the advice of Rob & Loony or take my advice: don't sell
Rowdy
S4R
May 21, 2013, 08:16:46 PM »
Quote from: NFG on May 20, 2013, 09:28:10 PM
I'd be doing the front rotors and new pads, foot peg rubbers, mufflers and the headlight. Maybe the seat depending on cost. Then find another bike shop to take it to. I've seen lots of used bikes at large bike dealers that have things like aftermarket exhausts, rearsets, fender eliminators etc done out the front for sale but the same shop will fail a customers bike for the same things.
Front rotors -
http://www.monsterparts.com/pc/EBC-XC-FR/CD-Brakes/EBC-XC-FR.html
Exhaust Baffles -
http://stores.ebay.com.au/BIRDS-BITZ-MOTORCYCLE-PARTS-SUPPLY/EXHAUSTS-BAFFLES-/_i.html?_fsub=18692907&_sid=135207610&_trksid=p4634.c0.m322
Foot pegs -
http://www.ebay.com.au/itm/Front-Foot-Pegs-Footpegs-Ducati-851-888-900SS-M900-/250850644304
(NOTE may not get you through a RWC as they might want to see foot pegs with rubber on them).
You greatly underestimate the amount of overconfidence I have.
Rowdy
S4R
May 21, 2013, 10:40:29 PM »
More baffles here
http://www.ducatimonsterforum.org/index.php?topic=63347.msg1170409#msg1170409
brad black
May 22, 2013, 03:47:23 PM »
Quote from: Rowdy on May 21, 2013, 08:16:46 PM
I spent years convincing management and several salesman that there were processes and procedures to be followed and installing such in regard to second hand bikes, the condition they were traded and sold under and preparing them for the floor and I might as well have been talking to the wall most of the time.
I would get people in for rwc and fail them (i was a real nazi) and they would then say, as above, "but this is how I bought it from you". then I would tell the boss he had to sign the rwc, which he would. and i'd go back to whatever else I was doing.
Brad The Bike Boy
http://www.bikeboy.org
Rowdy
S4R
May 22, 2013, 08:50:20 PM »
Quote from: brad black on May 22, 2013, 03:47:23 PM
You've gotta do what you've gotta do but this sucks for the customer. Funny how we want a pedantic and fastidious mechanic (hopefully not charging by the hour) servicing and repairing the bikes but a casual she'll be right RWC guy.
NFG
Newb
May 23, 2013, 06:24:14 PM »
Thanks for the replies and suggestions, guys. Very educational. =)
Quote
I spent years convincing management and several salesman that there were processes and procedures to be followed and installing such in regard to second hand bikes, [...] I might as well have been talking to the wall most of the time.
Fascinating. I'd much prefer to have a totally legit bike than get away with something I shouldn't. I think I might just have to get it all checked over by the same shop, if only to save the bucks it'd cost on the pipes and headlight. Most quality workshops (the independents) don't really want to have their name on the paperwork when the legitimacy is questionable - and that's a position I totally respect.
Fun times. =D
OzzyRob
May 23, 2013, 07:16:02 PM »
Fix it up and keep it or at least get another good 6 months out of it.
But dude some of these issues are things you should have been keeping a check on. Basic maintenance and the like. Specially the disc and sprocket thing.
FFS don't run with U\S discs.
NFG
Newb
May 23, 2013, 10:11:21 PM »
Oh for sure, but these things are all borderline necessary at the moment. They're due, but it's not critical (unless I need a roadworthy).
But yeah, I won't be riding it a lot until it's fixed. =)
suzyj
Does my bum look big on this?
May 24, 2013, 02:19:34 AM »
Quote from: NFG on May 23, 2013, 10:11:21 PM
a lot
at all
Fixed it for ya!
brad black
May 24, 2013, 02:50:40 AM »
you people worry too much.
you'd be amazed at what gets a few of my customers home on a continual basis.
Brad The Bike Boy
May 24, 2013, 02:22:55 PM »
Too true.
From an S4Rs, customer had no idea:
OzzyRob
Reply #14 on:
May 24, 2013, 03:05:53 PM »
Quote from: Speeddog on May 24, 2013, 02:22:55 PM
Too true.
Let me guess the complaint, clutch slipping ?
