S4R Redux
Started by TitanMonsterS4R, June 12, 2013, 08:26:34 AM
TitanMonsterS4R
After the woes and trouble with my S4 from the R/R failing, head gasket leak and valve adjustments needed after purchase, I just wasn't confident that it wouldn't fail for some reason or another.  Top all that off with the rear sliding out from behind when leaning in.
However, while deliberating as to what I should do with my S4, I found this S4R and it just felt right.
Despite having to replace the R/R shortly after purchasing, everything has been dandy since then.  Rides like a dream and has more torque than I know what to do with.
With only 4K miles on the bike, the PO didn't do much and what he did do was ehhh at best. The D&D pipes are gone and replaced with a Marving System that will later be swapped for either an Arrow or ExBox. The PCIII that was installed but not tuned has now been sorted out to eliminate the bottom end surging and fueling issue. Other bits have been changed here and there. But that's the fun in it I guess.
SpikeC
 Too bad that it's upside down!
Spike Cornelius
  PDX
2008 Bimota DB5R  woo-Hoo!
   1965 T100SC
TitanMonsterS4R
Quote from: SpikeC on June 12, 2013, 12:40:55 PM
it's right side up on my computer
joshuajcrouch
Congrats on having something that finally feels right.  Cannot wait to see what you do with this bike.
Oh and I vote ExBox btw.  I heart the open rear wheels with the SSS, and the ExBox only accentuates that.  Didn't see a poll option on this thread, so I was forced to plop my opinion right here :)
suzyj
I'd be really worried about oil starvation, running it upside down like that.
Quote from: suzyj on June 12, 2013, 04:49:16 PM
You guys are both in OZ...
right? ;D
TitanMonsterS4R
Quote from: ducpainter on June 12, 2013, 04:55:22 PM
right? ;D
You guys are all too funny.  Right side up, rubber side down.
SpikeC
Spike Cornelius
  PDX
   1965 T100SC
TitanMonsterS4R
Replacing the stock spring in my OEM Showa shock. Tech recommends a 7 inch, 425lb hypercoil spring.  I'm 164 without gear and the primary use will be for daily fun and weekend twisties.  Don't want it to be too stiff as DC doesn't have the smoothest pavement but dont want it to be mush either.  Does the spring he wants to use make sense?
suzyj
I replaced the stock spring with an Ohlins 01091 31/95, which has a 95kg/mm rate. That works very well for me.
TitanMonsterS4R
#10
Quote from: suzyj on June 17, 2013, 01:54:10 PM
Spring ordered from Kyle Racing.  Should be here tomorrow.  Will see how it gets along with the bike and me soon enough.
TitanMonsterS4R
TitanMonsterS4R
#12
Speedymoto triple arrived from JEFF_H over the weekend and I was able to finally convince a forum member to sell me his CycleCat rearsets and DP gel seat. Used a hacksaw and some other tools to shorten the "S" pipes on the exhaust to make the lines flow better.  That was a bit of fun.  Looks much cleaner without the two pipes hangin out the back.
Now I just have to be patient enough and take my time this weekend installing parts.  The new Ohlins spring arrived earlier this week, so it should be a good time getting everything sorted out for a Sunday ride.
TitanMonsterS4R
CycleCat rearsets and DP gel seat installed.  Triple and Penske rear shock with Ohlins fork is next  ;D
TitanMonsterS4R
#14
Current setup:
848 Masters with CRG levers
LSL Offset High Clipons with Rizoma Reservoirs/CRG Lanesplitter Mirrors
999 CF Front Fender
4 pad 4 piston calipers
ABM Front Rotors
Some cheap eBay turn signals
Ohlins Steering Damper
Tank painted by Ducpainter
Ducabike Gas Cap
Ducabike Frame Plugs
DucaBike Oil Cap
DucaBike Slave Cylinder
DucaBike Rear Sprocket Carrier
Rizoma/CF Belt Cover
TechSpec Grips
Speedymoto 10 Spoke Clutch Cover/Springs/Pressure Plate
Speedymoto Frame/Axle Sliders
Speedymoto EVO Waterpump
Speedymoto Crank Case Cover
CycleCat Rearsets
DP Gel Seat
Marving Midpipe/Exhaust
848 Rear Wheel with Galfer Rotor
Clear integrated Taillight with Signals
To Do List:
I still need to install the Speedymoto Top Triple, HID kit from Retrofit Source and remove the Penske shock, fit hte Ohlins spring reinstall and have suspension set.  Also need to remove the charcoal canister/silver frame stickers/wiring wraps.
