S4R Redux
Started by TitanMonsterS4R, June 12, 2013, 08:26:34 AM
muskrat
Quote from: TitanMonsterS4R on January 10, 2016, 04:38:09 PM
Can't believe you got rid of the S4R......Want me to buy a Multi and start the Mod bug for you
lets do it, we live once.
Can we thin the gene pool?
2015 MTS 1200
09 Electra Glide
TitanMonsterS4R
So curious to know what happens if I change the gearing. Currently the bike has a 14T/42T 525 setup. If I go up one in the back to 14/43 or to a 15/43, how will that change the bikes behavior?
Dirty Duc
Quote from: TitanMonsterS4R on January 19, 2016, 04:06:32 AM
A 14/43 will accelerate a little more quickly and have a little bit lower top speed.  Depending on your local cruise speed you may be at an annoying RPM during normal riding.
A 15/43 will accelerate a little more slowly and have a little bit higher top speed.  Depending on your local cruise speed you may be at an annoying RPM during normal riding.
TitanMonsterS4R
Quote from: Dirty Duc on January 19, 2016, 08:49:25 AM
Thanks DD.
The change from 14/42 to 14/43 is 2.4%, which is not much, at 60mph your rpm in 6th would be ~100 rpm higher.
That's roughly the width of the tach needle.
If someone snuck into your garage in the night and changed it, you'd likely not notice when riding it.
Going 15/43 from your 14/42 is a 4.5% change; slight, but noticeable, 60mph in 6th rpm would go down about 200.
TitanMonsterS4R
Guess my question should have been whats the best gearing for an S4R based on the following.
Pretty proficient rider with intermediate riding skills. Short commute in the city followed by weekend runs in the canyons. Enjoy my current setup but wanted to know if there a better ratio.....
Your current setup is exactly 3:1 ratio, and an even number of teeth on both sprockets.
This can lead to odd vibrations/harmonics.
Given that, and your riding profile and location, I'd recommend a 15/44 or 15/46.
Slightly higher and lower gearing than you have now, and ones that eliminate some of the harmonic possibilities.
Larger sprockets that last a bit longer, and are a bit nicer to the chain.
TitanMonsterS4R
Quote from: Speeddog on January 19, 2016, 03:25:58 PM
Never understood the vibrations. But this makes a lot more sense now......Useful bit SpeedDog.
Useful Cheers mate.
TitanMonsterS4R
It's time for some changes....
 [popcorn]
What you planning?
TitanMonsterS4R
Color schemes for the S4R/S4Rt/S4RS are as follows, am I missing any of them?
Ducati Monster S4R (996)
  Black Frame: Black Wheels/Black Tank/White Stripe
  Red Frame: White Wheels/Red Tank/White Stripe
                    Black Wheels/Red Tank/Black Stripe (2006 Only)
  Grey Frame: Red Wheels/Grey Tank/No Stripe
                     Grey Wheels/Red Tank/No Stripe
                     Grey Wheels/Blue Tank/White Stripe
                     Grey Wheels/Foggy Tank/No Stripe
  Blue Frame: White Wheels/Blue Tank/White Stripe
Ducati Monster S4R (998)
  Black Frame: Black Wheels/Black Tank/No Stripe
  Red Frame: Black Wheels/Titanium Tank/Black Stripe
                    White Wheels/Pearl White Tank/Red Stripe
  Gold Frame: Gold Wheels/Tricolor Tank/No Stripe
                     Gold Wheels/Blue Tank/No Stripe
Am I missing any colors?
Quote from: TitanMonsterS4R on April 05, 2016, 02:42:11 AM
I think you got them all.  But, I've never seen this one:     998 motor/Gold Frame/Gold Wheels/Blue Tank/No Stripe
TitanMonsterS4R
#222
Quote from: Duck-Stew on April 05, 2016, 10:52:33 AM
Thanks for confirming Duck-Stew. The gold frame/wheels and blue tank might have been a one off  my someone. Used Google images to produce my list.
Trying to find a rare but unique color combination. Very inspired by your Flight Cycles 900 that was black and gold. A fan of grey and red but also thinking something in the white range might be interesting.
Red/gold or any red color combo has been done, especially among the new Monster with those damn tank kits....
My experience has been that a bike looks best with 2 major colors playing off each other and a 3rd minor color to break things up.  If you have another color (like silver in for the engine & bits), that's totally acceptable.  It doesn't need to strictly adhere to a 3 color scheme, just 3 major colors.
TitanMonsterS4R
Quote from: Duck-Stew on April 05, 2016, 02:19:05 PM
Yup thinking is inline with you. Think I've got the colors narrowed down. Just need to figure out how to pull it all together.
