November 28, 2024, 07:39:06 PM *
News: Please Help
Author Topic: Rizoma grips slippery problem  (Read 2521 times)
kokis
« on: September 27, 2013, 04:20:58 AM »
It is gets cold in my area. I've got rizoma handle at my m696 and I noticed that if twist wrist and quickly release handle it sticks to it's position and slowly or sometimes suddenly goes back to 0.
I can accept that and probably solve it with some lube.
But what really questions me is that if I twist handle slowly at cold weather nothing happens until I reach ~25% of throttle open, revs does not goes up.
What to check?
« Last Edit: September 27, 2013, 11:47:53 AM by kokis » Logged
I am not pro in tech questions, but as any rider have some experience that I can share without claiming to absolute truth. Please use my advices responsibly.
« Reply #1 on: September 27, 2013, 04:23:38 AM »
The reason the revs return slowly is probably the grip hitting the throttle housing. You should fix that.
Do the rpms lag once the bike warms up?
kokis
« Reply #2 on: September 27, 2013, 04:56:40 AM »
Quote
yes. only at cold weather.
Also side-question/
I've got termi slip-ons after bike starts white smoke comes from only one barrel and closing it with hand does not make second one exhaust smoke. after few minutes there is less smoke comes out but some smoke starts to come out from second one. Is it normal?
ɹǝʌO d∩ uıɐןɐɹʇsn∀
Often wrong. Never in doubt.
« Reply #3 on: September 27, 2013, 05:09:43 AM »
This any help?
http://www.ducatimonsterforum.org/index.php?topic=27070.0
I like Rizoma bling muchly....  but their grips are absolute shite IMO.
Also side-question/
Yes, its normal.
« Reply #4 on: September 27, 2013, 05:12:15 AM »
Also side-question/
It most likely is running too lean.
Do you have the ecu to go with the Termi's?
The 'smoke' is condensation. Don't worry about it.
ɹǝʌO d∩ uıɐןɐɹʇsn∀
« Reply #5 on: September 27, 2013, 05:17:02 AM »
... slip on termis on my 696 used to do exactly as the OP described on start up....  puff of white "smoke" from one side... nothing from the other.
DP is right, it's condensation.
« Reply #6 on: September 27, 2013, 05:34:38 AM »
My old 900 does the same until it's warm.
kokis
« Reply #7 on: September 27, 2013, 05:57:18 AM »
Quote
yes. The more expensive ones.. feels not normal, just like handle and control unit moves together lol, like it moves on it orbit.
I know about condensation but barrels come from one pipe after all - weird that they work not simultaneously .
Thanks for your input guys.
So will lube fix handle?
ɹǝʌO d∩ uıɐןɐɹʇsn∀
« Reply #8 on: September 27, 2013, 06:29:58 AM »
replacing the shitty rizoma grips with anything else will fix the... handle.
kokis
« Reply #9 on: September 27, 2013, 07:02:49 AM »
just exterminated grip.
Seems like they were not designed for cold weather. Rubber\plastic base of the grip came loose at cold making top aluminum part of grip slide on it's base. Will try glue....
ɹǝʌO d∩ uıɐןɐɹʇsn∀
« Reply #10 on: September 27, 2013, 07:08:07 AM »
kokis
« Reply #11 on: September 27, 2013, 07:39:42 AM »
Quote
.Huh?
how the hell it came up like this.
EXAMINED
« Last Edit: September 27, 2013, 07:41:22 AM by kokis » Logged
memper
« Reply #12 on: September 27, 2013, 07:57:36 AM »
And here I was thinking this thread was about bad acting...
kokis
« Reply #13 on: September 28, 2013, 05:47:31 PM »
Have not fixed it yet.
Very disappointed with Rizoma brand.
Grips are simple and sometimes critical.
I was not able to move from red light as throttle did not responded.
I hope it will not happen in the middle of the corner.
