February 24, 2025, 08:00:29 PM *
News: Please Help
Author Topic: 2013 EVO M1100 - No more 14 tooth front for me! (and a gearing question)  (Read 6464 times)
Skybarney
Fako
« on: October 01, 2013, 06:32:04 AM »
When I was at 600 miles I had the dealer add a 14 tooth front sprocket to my bike as I did not like the stock gearing.  After riding 6k on the bike I was putting on the new slave cylinder and noticed a ton of rubber shavings were packed up around it.  Those shavings came from the rubber chain guard on the swing arm...... bang head  Much more of that and the chain will be eating into my swing arm.  So I am off to buy some new gearing and from the sound of it a new chain.
Stock gearing is 15-39 and I am thinking of going 15-42 although to keep the ratio exactly as it is, a 15-41 looks about perfect.  Now for the question;  In the real world just how different is the 42 over the 41?  Is it a large difference?  I don't want to gear much lower than it is but 42t sprockets are much more available than 41t's......
Thoughts?
Thanks!
ChrisK
« Reply #1 on: October 01, 2013, 06:49:09 AM »
I believe these are available in 41T's: http://ca-cycleworks.com/50608r
1998 M900
2007 CBR600RR Track Bike
1980 Lambretta Moped
Supra Boats enthusiast
« Reply #2 on: October 01, 2013, 07:00:29 AM »
think you have to go up odd numbers
Online Online
« Reply #3 on: October 01, 2013, 07:05:01 AM »
I went from 15/39 to 15/41 on my 900 and have had no issues.
I believe you're thinking of avoiding multiples.
Heath
« Reply #4 on: October 01, 2013, 09:42:03 AM »
Going up 2 3 in the rear is the same as going down 1 in the front.
Edit: oops fixed
« Last Edit: October 01, 2013, 09:46:25 PM by Heath » Logged
2007 Ducati Monster S4RT
Omnipotent Potentate
Personal Pretext
« Reply #5 on: October 01, 2013, 09:50:05 AM »
Going up 2 in the rear is the same as going down 1 in the front.
No... It's roughly, roughly 3 to 1
But let the computers do the maths for you.
http://www.gearingcommander.com/
ɹǝʌO d∩ uıɐןɐɹʇsn∀
Often wrong. Never in doubt.
« Reply #6 on: October 01, 2013, 01:23:11 PM »
Slide Panda is correct,  +3 rear = -1 front more or less.
brad black
« Reply #7 on: October 01, 2013, 04:20:09 PM »
if you had 14/39: 39/14 = 2.7857.
15 x 2.7857 = 41.7857.  or 42.
i'd run 15/43 on it personally.
Brad The Bike Boy
http://www.bikeboy.org
ɹǝʌO d∩ uıɐןɐɹʇsn∀
« Reply #8 on: October 01, 2013, 04:54:04 PM »
I took Brad's advice on this  waytogo
Suits me perfectly.
Curmudgeon
« Reply #9 on: October 01, 2013, 07:45:57 PM »
I'm wondering how you have your chain adjusted and/or your rear suspension set up as I've got ZERO signs of guide wear at the same mileage and we have essentially the same chassis.
Skybarney
Fako
« Reply #10 on: October 02, 2013, 04:51:15 AM »
Chain adjustment has been kept perfect.  However the $189.00 rubber guide is well on it's way to replacement  bang head  I just ponied up for a quick change 15-43 520 setup and a new chain.  Sad as I only have 6k on the chain and sprockets and they show little wear.
Curmudgeon is yours a 2013 or a 2012?  I have found a lot of parts on my 2013 that simply don't fit like they should......
Curmudgeon
« Reply #11 on: October 02, 2013, 06:15:17 AM »
Read my signature line.  Cool
Narflar
Beware the wrath of my
Professional Lurker
« Reply #12 on: October 02, 2013, 08:47:11 AM »
I'm curious as to how much wear you saw.  I have 3000 miles on my bike with a 14 tooth sprocket.  I pulled the sprocket cover to see if there was any aggressive wear and there is a little bit where the swingarm ends and the chain starts to make its turn around the sprocket.  Only normal fling and such on the engine case around the sprocket.
I tried to take a pic of what I saw.  This was the best I could get.  I lifted the chain at the worst part I saw where the swingarm ends.
2012 Ducati Monster 1100 Evo
2008 Honda ST1300
2008 Triumph Speedmaster
2004 Ducati M1000
dbran1949
2007 S4RS Black Termis
« Reply #13 on: October 04, 2013, 04:40:11 AM »
I've posted a few this times before, when faced with the sane question on my S4RS i put together a quick excel spreadsheet then sorted by ratio
Front   Rear   Ratio
15   38   2.533
15   39   2.600
15   40   2.667
14   38   2.714
15   41   2.733
14   39   2.786
15   42   2.800
14   40   2.857
15   43   2.867
14   41   2.929
15   44   2.933
15   45   3.000
14   42   3.000
15   46   3.067
14   43   3.071
15   47   3.133
14   44   3.143
15   48   3.200
14   45   3.214
15   49   3.267
14   46   3.286
15   50   3.333
14   47   3.357
14   48   3.429
14   49   3.500
14   50   3.571
as you can see 14/38 and 15/41 are identical for all intents and purposes
