my M900
Started by pepeducat, October 17, 2013, 05:13:06 AM
Pinion
Nice work. Have you tried any of the motogadget relays?
Will trade toilet paper for parts
pepeducat
how does the inregrity of the gears holds with those mods?
pepeducat
It's winter, so big winter work.
It's time for the dismantling of MOSTRO
The exhaust manifold will have a small shot of polish
The wheels will be sanded then painted in satin black and the bearings will be changed
The electrical circuit goes to the trash and will be replaced by a Munit MotoGadget
Dismantling the front axle
Frame came out and you can see the stop that was broken when I fell in 2016 ..... [bang]
And now disassembly finished ....
greenohawk69
What front lift are you using?
"An enlightened people, and an energetic public opinion... will control and enchain the aristocratic spirit of the government." --Thomas Jefferson to Chevalier de Ouis, 1814
There are 4 boxes to be used in the defense of liberty:  Soap, Ballot, Jury and Ammo.  Please use in this order.  -- Ed Howdershelt
pepeducat
greenohawk69
pepeducat
Work in progress
Modification frame 😎
pepeducat
Wiring harness and motogadget
ducatigirl100
#103
 I like the wiring... it always looks like that at that stage  your on the rigth track....... [popcorn]
Also  you may need to put a groud wire (AWG 14 size is ok)from one of the 2 bolts of the M-Unit to the frame.... the black wire that goes to the batery is not enough.   Your m-unit seams to be bolted to a  painted steel plate you sould be ok but just in case , the info may be ussefull..  [thumbsup]
Epic job  [thumbsup]
Igor900
Nice. I just finished taking mine all apart last week. Waiting for the frame to be painted then I get to put it all back together slowly lol.
Good luck with the wiring. That's one thing that scares me with trying to work on. I can do all the mechanical stuff, but wiring just confuses the hell out of me.
