Trouble Getting Going
Started by ChrisK, March 10, 2014, 03:19:06 PM
Ok, use the manual petcock and oem fuel pump and jet that sucker!
Try a baseline of one of the jetting combinations mentioned and work from there.
Understand that there is jetting for these carbs that is ok, jetting that great and jetting that is awesome.
You have shown a lot of patience and jetting carbs requires it. You might get it spot on or close enough to ride the bike for a few weeks before you think there is an area in the carburation you want to change.
What jetting combo you going to try?
ChrisK
#121
Quote from: koko64 on March 13, 2014, 06:22:36 PM
I know it takes patience, it's just so hard to have it when the weather is FINALLY warming up around here. I went through at least a dozen jetting changes when I installed Dynojets in my Mikunis, so I'm used to this part I guess.
I'm going to order 2x:
Mains, 165, 160, 162
Slows, 55, 52, 50
When I get them in the first setup I will try will be 165 mains, 55 slows, and 5th needle position.
Any other suggestions welcome!
1998 M900
2007 CBR600RR Track Bike
1980 Lambretta Moped
Supra Boats enthusiast
ChrisK
Also, whoever said jets are cheap just wasn't correct. Yes, as individuals they are. But when you have to buy two of each in 6 sizes...
$83.40. Glad I'm not tuning an old four cylinder...
1998 M900
ChrisK
Is there much of a difference between Genuine OEM Keihin jets and "OEM equivalent" jets?
They're half the price.
1998 M900
Expensive to you, but cheap down here ;D
CCW has cheaper equivalent jets iirc.
I know the slow jets are the same as in Harley Keihin 38mm butterfly carbs on 80s models. I found them cheap at my Harley dealer.
If CCW have run out you could try Powerbarn , Brad mentioned them a time back. At least you can keep them if you need them when you fit the V heads or other mods.
It would be tough after a hard winter.
ChrisK
I ended up going with OEM equivalents from a company called Jets-R-Us in Missouri. $3.19 for the mains and $4.67 for the slows. Brought the total to $47~. That's much easier to swallow.
1998 M900
Just checked them out. Another good site for jets. You guys got shops everywhere!
Quote from: ChrisK on March 14, 2014, 06:18:31 AM
I know it takes patience,  I went through at least a dozen jetting changes when I installed Dynojets in my Mikunis, so I'm used to this part I guess.
So you are well versed in the airbox/battery box removal drill [bang].
I separated the airbox from the battery box. I run a small Li battery so there was no strain on the battery box bolts. I cut at the join between the two and removed material, but leave enough for the battery straps. On my own bike, I trimmed down the battery box and used the bung holes to fit straps. I also cut off that annoying little alloy tab on the Ignition/steering lock that snags the front of the airbox on install [bang]. With a dremel, I made little arches above the tops of the FCRs top cap so I just remove the battery box to access the needles with the airbox in place. Removing just the battery box is so much quicker. I change main and slow jets via the drain cap and float bowl. Airbox stays put.
Speeddog fit stabilizing brackets between the airbox and battery box. Imagine one end of the bracket bolted on and one end with Dzu fasteners; trick!
I can email you pics if you PM me.
ChrisK
Wow, that sounds great, can't believe I didn't think of that.
I'll send ya my address.
1998 M900
Sorry about the pics. I didn't have any during the mods. The lighting wasn't real good, but I think you get the idea.
ChrisK
You were right, Koko, that is much easier like that.
Needle clips at the 5th position now, just waiting for the other jets to arrive.
1998 M900
ChrisK
After eliminating the vacuum operated petcock, what do you guys do with the old line? Is there a cap you can get to replace the hose or something like that?
1998 M900
Quote from: ChrisK on March 16, 2014, 03:27:19 PM
Auto parts store should have a vacuum cap. 5mm would be 3/16"
+1.
I think I also may have plugged one with an alloy bolt and clamp and used it for synching the carbs. Then I did a set up on the other outer side.
The caps are neater.
ChrisK
1998 M900
