remove wet clutch from 620ie without special tool how?
Started by cmejia1978, May 08, 2014, 06:08:04 AM
cmejia1978
hi there! I have a kind of a "brand new" wet clutch sitting on a shelf to replace my 20,000kms or more (have no gauges since 9,000kms), but I am stuck without the special wet clutch holder, any advice? can I make it without it? thanks!  [popcorn]
caperix
I used an impact wrench on mine & did not have any issues.  When torquing it back down I put the bike in gear & had a friend hold the rear brake.
You plates should still be fine after only 20k kms.
I put a good *used* set of plates in my M750 20k miles ago, and they're still good.
Unless the basket or hub are damaged, all you would need to do is swap the plates.
No special tools necessary for that.
Is it slipping or otherwise not performing properly?
He just wants to install the brand new one . . . ;D
It's a 2002 so no APTC
xsephirot
Will the dry clutch holder work with wet clutches? http://www.amazon.com/Ducati-Clutch-Basket-Holder-Tool/dp/B006M59FJO
And what solvent should I be using to clean the basket and the securing nut? I plan on doing the loctite thing.
The dry clutch tool will work with the non-APTC wet clutched.
Quote from: xsephirot on May 08, 2014, 02:44:32 PM
Values have been redone, don't remember from top of my head but it's a lot more than before . . .
I'll give you the value tomorrow and what chemical agent to use
Unless you're just itching to replace, I would leave it.  My M750 has 37,000 miles and counting on its original clutch.
JM
xsephirot
Quote from: xsephirot on May 09, 2014, 11:59:53 AM
What about for APTC clutches? This tool? http://ca-cycleworks.com/mp08-0008-p518
APTC hub is two pieces, the outer that has the teeth to engage the steels has a flange on the outboard end.
So that tool won't fit.
That tool does work well on the regular wet and dry clutches.
xsephirot
Quote from: Speeddog on May 09, 2014, 12:21:39 PM
Thanks for all the help Speeddog!
BK_856er
Don't know if this helps, but below is the APTC clutch (1) assembled, (2) with factory tools installed and nut removed, (3) parts off bike.
BK
cmejia1978
Thank you all! the things is that when I change gears it does a loud "TACK" sound and also sometimes, not all the time but every 2-3 days when I am going home, maybe at 120-130km/h and shift from 4 to 5 it will slip and I have to lower the speed to engage again the 4th...  [thumbsdown]
BK_856er
Quote from: cmejia1978 on May 10, 2014, 08:28:27 AM
My APTC wet clutch is particularly sensitive to oil type.  Even within a given weight + moto-specific group it matters.  I've consistently had the best CLUTCH performance with Mobil-1 Racing 4T 10W-40, so that's the only oil I use.
BK
ducej
Quote from: BK_856er on May 10, 2014, 11:54:38 AM
BK
Agree on this one. I switched once to a 15W-50 and clutch started to slip in higher revs. Took me 2 oil changes with 10W-40 to have it back to normal. I don't notice difference between Mobile-1 or Shell advance. At this moment I use Fuchs Silkolene 10W-40 with good clutch performance.
S2R Icy yellow, chopped tail, rizoma mirrors and indicators
Honda Spacey
