January 09, 2025, 08:29:23 AM *
Author Topic: S2R back end not gripping very well in corners.  (Read 2987 times)
Ducatiloo
« on: July 10, 2008, 07:50:00 AM »
Last week I went over a large patch of tar while taking a left corner at about 20 mph max.  The entire bike slipped over no more than a few inches to the right.
Since then when I take corners, left or right, it gives me the same feeling as riding in the rain on a newly oiled road.  Tire pressure is unchanged and I cannot feel anything out of the ordinary on either of the tires.  Front tire has about 6 k on it and the rear has about 300-400 miles on it.  Any ideas?
750 SS 01    800 S2R 05  Aprilia RST 1000 futura
SKOM
Upside Down Canuck
« Reply #1 on: July 10, 2008, 07:53:56 AM »
Maybe there is still some of the tire mold grease left on the rear. Should have scrubbed off by now though.
Could it be a mental thing?  Undecided
"Die gefährlichste Weltanschauung ist die Weltanschauung derer, die die Welt nie angeschaut haben."
— Alexander Von Humboldt
Ducatiloo
« Reply #2 on: July 10, 2008, 08:01:11 AM »
It's not a mental thing.  I wan't freaked out or anything by sliding just angry at the state of the roads in town.
SKOM
Upside Down Canuck
« Reply #3 on: July 10, 2008, 08:06:22 AM »
I hear you. Up north here there is TONS of cracking to the asphalt which means lots and lots of those tar strips.
They sure do get slippery when it's hot out.   bacon
« Reply #4 on: July 10, 2008, 08:35:35 AM »
What tire do you have on it?
Can you put it on a rearstand and spin the wheel, see if the tire has gone lumpy or otherwise look not round?
Ducatiloo
« Reply #5 on: July 10, 2008, 08:50:26 AM »
I have Pirelli Diablo’s.  I looked at the tires and they did not look squared or lumpy.  Could a belt have broken in carcass?
sbrguy
« Reply #6 on: July 10, 2008, 09:02:44 AM »
if you think there is some residual tar or anythhing on the tire, spray the tire with brake parts cleaner and wipe off with a rag, this will get off any remaining oil or tar on the tire so you can see if that is what is doing it.
« Reply #7 on: July 10, 2008, 09:04:10 AM »
carb cleaner works to.
Radial tires dont break to often. After you clean it, you should get someone you know to ride it and see if they have the same opinion. It could just be the surface your on is not too grippy and you never noticed till now.
Ducatiloo
« Reply #8 on: July 10, 2008, 09:13:19 AM »
Thanks guys I'll give cleaning my tires a try tonight.
tangueroHondo
« Reply #9 on: July 10, 2008, 09:34:15 AM »
No one's mentioned suspension: Maybe you need to dial back that damper and afford it some more give.  Maybe she's a little stiff in the corner and not settling down?
Ducatiloo
« Reply #10 on: July 10, 2008, 10:14:30 AM »
I tried that last night, it had more give but still felt unsettled.
« Reply #11 on: July 10, 2008, 11:02:20 AM »
A broken belt in the carcass will usually give itself away by a lump or out-of-round condition.
What pressures are you running?
Ducatiloo
« Reply #12 on: July 11, 2008, 08:10:24 PM »
I figured out my issue.  I was out riding, suddenly my front end started pulling side to side and couldn't keep it under control above 60 mph max.
When I got home I discovered my front tire was badly squared out.  I had checked before I orig. posted but the tires looked fine.
Oh well time for another Pirelli Diablo waytogo
