January 10, 2025, 07:26:41 AM *
Author Topic: question regarding fuel tank swap 2002 M750ie  (Read 1427 times)
dansamp
« on: August 07, 2014, 02:34:34 AM »
my tank is leaking and I have not found someone to repair it so I need to replace it
I found this : http://www.ebay.com/itm/2000-on-Ducati-Monster-900ie-FUEL-INJECTED-58610312AE-metallic-blue-NOS-gas-tank-/161255784408?pt=Motorcycles_Parts_Accessories&hash=item258b97ffd8&vxp=mtr
and am hoping it will fit my bike
I know there was a seat mounting change in early 2000 and am not sure if the seat cut out on the tank is the same for this tank compared to my 2002
hope someone can let me know
thanks in advance  waytogo
Dan
« Reply #1 on: August 07, 2014, 02:38:52 AM »
2000 and up steel tanks have the same cutout for the seat.
93-99 shared the other style.
« Reply #2 on: August 07, 2014, 05:59:28 AM »
Seat cut-out: Same from 2000 to 2008.
Under tank sheetmetal around the battery: 2000 to 2001 2V bikes: Same.  BUT: 2002 to 2005 (last of the steel tanks): Different.
In 2002 when the battery got moved from it's old vertical position to the horizontal position above the vertical cylinder head, it necessitated a change in the sheet metal for the lower tank stamping.  They will NOT interchange w/o battery relocation, possible wiring changes and maybe even an airbox change (if that's possible).
ducrider45
Just Ride!
« Reply #3 on: August 07, 2014, 06:40:15 AM »
Yes, this is correct.  waytogo
 Thomas Jefferson
« Reply #4 on: August 07, 2014, 06:58:12 AM »
The 02 750 was a one year deal with the FI.
Did they go to the horizontal mounted battery?
« Reply #5 on: August 07, 2014, 10:00:35 AM »
Yes and it was a horizontal battery.  1 year only w/the 5.9ecu and 750 motor.
dansamp
« Reply #6 on: August 07, 2014, 10:15:31 AM »
Well that sucks !!
But thanks for the info
At least I didn't waste the money
Back to the drawing board   Huh?
SpikeC
Spike in PDX
« Reply #7 on: August 07, 2014, 11:11:37 AM »
 You can make anything work if you want to badly enough.....
Spike Cornelius
  PDX
2008 Bimota DB5R  woo-Hoo!
   1965 T100SC
brad black
« Reply #8 on: August 07, 2014, 11:50:32 PM »
say hello to mister hammer.
Brad The Bike Boy
http://www.bikeboy.org
