fuel level sensor
Started by scaudill, January 22, 2015, 05:33:11 AM
scaudill
Will this ebay item fit and function on my 01' Monster tank?
http://www.ebay.com/itm/161474628005?_trksid=p2060778.m1438.l2648&ssPageName=STRK%3AMEBIDX%3AIT
The seller does not offer returns on this item.  So I would appreciate some help.
Sterling
If you would tell us a little more about your bike . . .
Model 900/750/600 . . . carb/efi . . .
But, here are all part numbers for fuel level sender unit for 2001 Monster
PN:
for for 900ie 59210172A
for 750 carb 59210132A
for 600 carb 59210083A
If it is a metal tank it will fit.  What amount of fuel left will light the light if it is installed in a Monster tank?  Dunno.  Rudemouthsky just bought one  http://www.ducatimonsterforum.org/index.php?topic=69869.0
scaudill
My bike is a 01' 750 Monster with metal tank.  I think the ebay sensor is the way to go.  Maybe I can remove the connector form the bad sensor and use on the new.
Thanks,  Sterling
Quote from: scaudill on January 22, 2015, 10:05:50 AM
Thanks,  Sterling
If this is your bike, then PN 59210132A is the correct part and fits ALL CARBED Monsters from 90-04[M400], but, not EFi or ie Monsters . . . Info directly from Ducati parts catalog
PN 59210071A = 59210072B will only fit SBK 748-851-916-996 . . . will not fit ANY Monsters
Wished I could give you an image, but, working on two separate laptops one is intranet and this one internet
Quote from: howie on January 22, 2015, 09:57:10 AM
howie, it is the same part as the one the OP is looking at
From experience there is two lengths of senders. The shorter length is for Monsters IIRC. The FI vs carbie doesn't matter regarding the nut...all Ducs share a common size. The fi has 4 wires in the connector and the carbie has two, which can be swapped. The wires to feed the pump can simply be snipped off on the tank side and the connector side of a FI sender to use on a carbie.
GK
Mine's cactus also! Nuts!
Thanks for those part numbers Carlos, I'll ring my local dealer to see how much I'm up for.
2001 Ducati  Monster 900S ie
Gone but not forgotten!
Odometer. My new one died in a few months.
