April 20, 2024, 12:16:35 AM
Statler
Old car build thread
35
36
37
38
39
Topic: Old car build thread (Read 80748 times)
For $50 you can touch my
Re: Old car build thread
Reply #525 on:
June 20, 2022, 03:26:45 PM »
One rocker was fine. This isn't it.
Reply #526 on:
June 20, 2022, 03:28:37 PM »
I cleaned up the engine compartment:
Also replaced all the vacuum lilnes, heater lines, heater core, fuel lines, and rebuilt the carb and fuel pump.
Oh, and I replaced the fuel lines too.
Reply #527 on:
June 20, 2022, 03:30:50 PM »
The DMV wanted to know the mileage.
No problem.
I'll just remove that and....
and remove that bit in the way and....
If you look down from the top you can read the numbers and extrapolate which ones were in the front. Easy.
Reply #528 on:
June 20, 2022, 03:32:53 PM »
Painted the floor.
And the inner fenders
Moved the batteries from being a large center console to behind the seats, as I need at least a three seater.
It was a fire truck. I don't know what all these holes are for.
Reply #529 on:
June 20, 2022, 03:34:46 PM »
Prime:
I put sound deadener on the floor as the drivetrain is really noisy.
It's got no roof, so it won't help, but it looks better than the paint, so there's that.
Reply #530 on:
June 20, 2022, 03:36:21 PM »
The astute will notice the roller on the floor.
There wasn't room to spray it in the shop, so that's what it got.
Shiny.
Reply #531 on:
June 20, 2022, 03:40:07 PM »
make the beast with two backsing thing still won't run.
I mean, it will, but not in the stock configuration. The fuel pickup is plugged solid, and it looks like that put that in before they closed up the tank.
Gas goes it. Gas no come out.
No one makes one that I can find, and the local radiator shop that used to do such things told me to get stuffed today.
There's that and making the signals signal. Then I can tow the boat, which I also fixed.
It's been busy-all this since November.
Reply #532 on:
June 20, 2022, 03:43:18 PM »
Roller?
Reply #533 on:
June 20, 2022, 03:46:41 PM »
After all your teaching.....
It was that or spray it outside.
Feral 859
Reply #534 on:
June 20, 2022, 05:01:58 PM »
Oh hell yeaah!
“Woohoohoohoo! Two personal records! For breath holding and number of sharks shot in the frickin\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\' face!“
Randimus Maximus
'01 996SPS
Reply #535 on:
June 20, 2022, 06:27:58 PM »
Is your arm back to normal? Maybe I missed a post or two on that?
Cool projects!
you may be a god
Reply #536 on:
June 21, 2022, 02:59:12 AM »
Rotator cuff is healed and my wrists are better, too! I can actually work at a real rate again.
Now to find a fuel tank
Reply #537 on:
June 21, 2022, 07:33:17 AM »
I found a guy who said he'd fix it (I sure ain't self-teaching how to braze a fuel tank).
He would probably call Nate a whipper-snapper.
Speedbag
And the Intrepid
Since 2004!
Reply #538 on:
June 21, 2022, 08:26:31 AM »
Quote from: ducpainter on June 20, 2022, 03:43:18 PM
Roller?
You have to admit, it has a fair amount of shine in the pics.
triangleforge
I'm just a guy. I'm no
2000 Cagiva Gran Canyon
Reply #539 on:
June 21, 2022, 01:18:33 PM »
Quote from: Speedbag on June 21, 2022, 08:26:31 AM
That was surprising - I've seen my share of latex-roller paint jobs, and that's several orders of magnitude better looking.
35
36
37
38
39
=> Stalla's Pop
