Ducabike Rearsets Brakefluid Hose
Started by The ModFather, April 19, 2015, 03:20:07 PM
The ModFather
Ducabike Rearsets on an older monster (2005 620). There's no way the stock brake hose is going to reach to where the brake fluid reservoir was orginally bolted in. What do most people do here? Put on a longer hose or mount the reservoir elsewhere?
2007 Sport Classic 1000S
2008 848 Track Bike
2015 Diavel Dark - Sold
2005 Monster 620 Dark - Sold
Quote from: The ModFather on April 19, 2015, 03:20:07 PM
It fits . . . No promises but will try to find pic of my bike . . .
gotta fiddle with it a little
The ModFather
Mine doesnt seem to reach at all. Never thought Id ask a guy this but.. Whats the length of your hose?
2008 848 Track Bike
Quote from: The ModFather on April 21, 2015, 09:57:56 AM
Jajajajajaja . . .
It is the OEM hose . . . I have only replaced the fronts
good time to replace the hose, esp if its the oem hose.
JohnEE
I used Tygon Tubing from Kurvey Girl(odd name, I know)when I installed the ducabikes rearsets on my M695
https://www.kurveygirl.com/shop/index.php?cPath=106&osCsid=34k5rhlt8u9787nbh4s2mfma71
I think motowheels has it also
The ModFather
Quote from: ducatiz on April 21, 2015, 12:07:51 PM
Why do you say this? Is there an issue with the OEM hose?
2008 848 Track Bike
The ModFather
I'm actually thinking of replacing the rear brake reservoir. Does size matter? (no pun intended)
2008 848 Track Bike
ducatigirl100
I add the same problem ...but whit the rizoma rearsets
I've use the original  brake hose... I moved it to the side ... and the brake fluid redervoir is the same size , I made a bracket for it ...
Here's a pic....if it helps  [popcorn]
The ModFather
DucatiGirl100 which size Rizoma did you get?
2008 848 Track Bike
ducatigirl100
The fluid reservoir was the small one  [thumbsup]
As noted, go with Tygon if yoy want some new hose
The ModFather
Thanks for the pics! Where do you put the sensor for the brake light?
2008 848 Track Bike
