Oil leaks from oil filter
Started by bob795, May 20, 2015, 11:40:19 PM
bob795
Hi guys,
I have some questions for you. My bike is leaking oil. Oil is coming from the oil filter, looks like it's coming from the spot where the oil filter touches the engine case. This is the third time it happens to me.
The first time it happened, I fixed it myself by changing the oil filter. The second time it happened, it was fixed by the dealer... I guess fix is not the right word cause the fix was done at the same time I did a 10,000 km service.
Every time, this leak happened after I revved up my bike. The latest one was last night.  On my way home from the office,  I revved up my bike, I stayed in 1st gear until I reach 82 kph before I shifted to 2d gear. I remember looking at the speedo and thinking :"whoa, this bike is quick  ;D " This morning when I was going to go to the office, I noticed there are drops of oil underneath my bike. Sure enough, it came from the oil filter. Same place as before. So I left my bike at home today and take my other bike.
My questions to you guys:
1) is this leak is caused by the oil filter getting loose (vibration causing it to become loose)? I'm thinking maybe it's the cause because it happens after I revved up the bike hard; or is it something more serious?
2) is this leaking from the oil filter is something that often happen to Monsters?
BTW, I ride / commute on this bike every day... usually I ride it for a week then the next week I ride my Husky, then the monster again ,so on and so forth.
Thanks guys,
bob
2011 Husqvarna TE 630
2012 Monster 795
2002 Sportster 883/1200 (sold)
It's a common problem if the filter isn't tightened properly on install. They can't be just hand tight like on a car.
Tighten it with a strap wrench.
bob795
Thanks ducpainter.
I'll look for a strap wrench. I just visited monsterparts looking for an oil filter tool, but too bad they don't it in stock.
bob
2012 Monster 795
If Jeff doesn't have one ca-cycleworks or motowheels might.
They're all long time sponsors.
You can probably find one at autozone if you bring a filter.
BTW...there is a torque spec for the filter, but I just tighten the thing.
Tighten to 17 Nm.  No torque wrench or tool?  7/8 turn after gasket contact will work.  Once they leak,sometimes they continue to leak after proper tightening.  If you can get K&N filters where you are they have a 7/8 nut on the bottom.
bob795
#5
Thanks again ducpainter, I'll go check ca-cycleworks and motowheels sites.
Thanks Howie... I remember seeing one online store here where I live, that sells K&N oil filter with nut on the bottom. I'm gonna look for it.
bob
edit:
motowheels has this: http://motowheels.com/i-14171579-corse-dynamics-billet-oil-filter-wrench-v2-ducati-oem-filter.html Can I use this?
2012 Monster 795
Yes. It works with oem filters. If you are committed to oem filters it would be a good purchase.
I like the K&N filters.
Try tweaking tight a bit more by hand and see if the leak stops. Use one of those rubber jar openers that help your grip. After that buy the K&N filters so you can use a wrench. Just my preference.
I just picked up some K&N filters from MW.
bob795
Thanks koko64, I'll try that.
2012 Monster 795
memper
Try tightening first before replacing. Also, maybe a dumb comment, but did the rubber gasket come out with the last oil change? Sometimes it gets stuck on the case and doesn't come out with filter removal and goes unnoticed. Then the new filter is installed and the gaskets are doubled up which would probably result in a poor seal.
Wouldnt be the first time that happened.
+1 on the strap filter. It's a handy tool as it fits many filters, so add that to your tool box list. ;)
Quote from: koko64 on May 21, 2015, 04:35:35 AM
Hadn't thought about that, good tip  [thumbsup]
JM
MotoPsycho
Might help too like automotive stuff to smear a coat of new oil on the gasket ?
Quote from: MotoPsycho on May 27, 2015, 03:13:21 PM
That's a given...SOP.
MotoPsycho
I've seen people not do it plenty of times and tear the hell out of a filter trying to get it off, it's easy to overlook.
