January 06, 2025, 07:22:45 AM
M796 bars
Topic: M796 bars (Read 7136 times)
Dochunt
M796 bars
May 25, 2015, 06:40:12 PM »
Being taller I would want the bars a little high.
Any thoughts on whats better, just using risers or replacing the whole bar with an aftermarket one.
Thanks in advance
Aprilia Caponord 1200 2015
M796 ABS 2012
Triumph thunderbird Sport 1998
ɹǝʌO d∩ uıɐןɐɹʇsn∀
Often wrong. Never in doubt.
Re: M796 bars
May 26, 2015, 05:55:10 AM »
risers are less hassle IMO
Ducati
1100S
Monster
Ducati
1260ST
Multistrada
Moto Guzzi
Griso
1200SE
Previously:
Ducati
1200S
Multistrada
Ducati
Monster
696
Ducati
SD
900
Moto
Morini
Dochunt
raising the Bar on M796
May 28, 2015, 09:51:26 AM »
I am thinking of raising the handle bars with some extenders.
Do you all think this will affect the handling character of the bike.
I can live with the stock bar but would be a little more comfortable if it was an inch higher.
I don't want to make this change if it will affect the bike a lot because the handling is so good the way it is now.
Your thoughts please.
Thanks
M796 ABS 2012
S21FOLGORE
Re: raising the Bar on M796
May 28, 2015, 11:05:18 AM »
How tall are you ? And what problem are you trying to solve with bar riser?
In most case, fitting a bar with different bend (and usually they are a bit higher than stock) is a better solution.
http://www.ducatimonsterforum.org/index.php?topic=52588.msg965870#msg965870
Dochunt
May 28, 2015, 11:09:34 AM »
I am 6'2".
The riding position is ok but on long rides I feel it would be better if I could sit a bit more upright,
Thanks for the input
M796 ABS 2012
Curmudgeon
Re: M796 bars
May 28, 2015, 01:59:55 PM »
Quote from: ungeheuer on May 26, 2015, 05:55:10 AM
Hmmm... A slightly higher Rizoma bar costs little more than risers and has more sweep which is much kinder on your wrists!
(You'll have to drill the locating holes for the controls.) A bit less vibration too.
http://gallery.leica-users.org/d/282951-1/Rt_-Above.jpg
See the diagrams. Mine's an MA008A.
http://www.motovationusa.com/mvstore/Scripts/prodView.asp?idproduct=562
Curmudgeon
May 28, 2015, 02:09:29 PM »
http://www.ducatimonsterforum.org/index.php?topic=71009.msg1312143#msg1312143
Suggest you fit those knee pads too for riding in slow traffic.
http://www.monsterparts.com/pc/621500SS/Accessories/621500SS.html
Dochunt
Re: M796 bars
May 28, 2015, 02:27:00 PM »
Thanks, I will check it out
M796 ABS 2012
S21FOLGORE
May 28, 2015, 04:15:33 PM »
Ah, okay. I don’t know how it feels like to be “too tall” for Monster.
BUT, the same logic applies here. If you want “slightly more upright” riding position, often times, all you need is to move the grips (hand controls) a bit closer, NOT higher, with more comfortable / natural sweep back angle of the grips.
As for if it affects the handling of the bike, if you move only a small amount (eg, no need to change throttle cable, clutch & brake lines, you’re fine.
Dochunt
May 28, 2015, 04:19:55 PM »
Could I just rotate the handle bar backwards a bit? or do I need to replace the bar with an after market one
M796 ABS 2012
Curmudgeon
May 28, 2015, 04:20:18 PM »
The MA 008's have ~ 3/4" more rise and 2 1/2" more sweep than the stock 796 bar, about the limit of the lines and cables.
Dochunt
Re: M796 bars
May 28, 2015, 04:24:16 PM »
I am not that mechanically inclined thou I am learning.
Any idea how much this will cost to get done by someone
M796 ABS 2012
Curmudgeon
Re: M796 bars
May 28, 2015, 05:12:28 PM »
Quote from: Dochunt on May 28, 2015, 04:24:16 PM
Around $150 - $200 tops all-in including the bar. Depends on your dealer's labor rate. In South Jersey? Call Ferracci and ask. You should have everything adjusted and drilled while you sit on the bike.
Dochunt
Re: M796 bars
May 28, 2015, 06:48:34 PM »
Okay Thanks.
I am in-between Ferraci and the Metuchen dealership, I call them both.
M796 ABS 2012
Curmudgeon
Re: M796 bars
Reply #14 on:
May 28, 2015, 07:57:15 PM »
No experience with Metuchen but are you sure you want to ride to Northern NJ.
Isn't that a Kawasaki dealership?
Maybe they are wonderful. I'd ask somebody local though.
Ferracci only sells and works on Italian machines. I'd guess they'd be more sympathetic to your needs but it's been eons since I last did business with Eraldo. Your call. Maybe his son, Larry, runs the place now? No clue.
Did you ever fit a 14T front sprocket? It's cheap and they could do that for you too. Just be sure to get the right one as it only fits the M796 and Hyper 796, Driven Racing #1067-525-14T.
