Anybody done a GP shift on an 821?
Started by MotoZen, May 30, 2015, 11:36:58 AM
MotoZen
What's up peeps? I'm considering converting to GP shift (1-up / 5 down) on my M821. Have any of you guys done this? I'm looking for general opinions and tips on making the conversion.
Indian dirt-bike with training wheels -outgrew 25 years ago
XR 80 - outgrew 20 years ago
2015 M821. - will probably never outgrow
Sorry for the bump, but I don't see anything else on the subject.
I switched the setup so that it's reverse now, but it's not ideal. I can't get the shifter as low as I'd like without binding.
I haven't seen an aftermarket reverse shifter for it.
Anyone?
Get a new shifter arm
The mount is likely the same as. Any other 4 valve motor minus panigale
Quote from: Raux on September 30, 2015, 11:14:54 AM
I'm not sure though. I tried to swap the shifter from my S2R1000 and it hit the rearset...
The gp shifter you can buy?
Quote from: NAKID on September 30, 2015, 11:37:40 AM
Too long?
Quote from: Raux on September 30, 2015, 04:38:07 PM
Yes, I tried to swap the SSR reverse shifter I installed on my S2R1000 and it touches the where the rearset mounts to the frame. Are you referring to the shifter that has a bend in it to give it some clearance?
I see your issue now. Try a longer shift rod and see if you can get it to work that way
Quote from: ducpainter on October 01, 2015, 05:45:17 PM
How about a shorter shifter?
http://motowheels.com/i-6923173-short-billet-reverse-shifter.html
Maybe, I'll have to check the length of my existing one when I get home. This might work.
That's a no go. Length of that shifter is 4 1/4". Spline to closest point of contact is 4".
I think the off set ones might work. $100 bucks though...
Quote from: NAKID on October 01, 2015, 08:39:42 PM
I guess it depends on how everyone is measuring.
Is it 4 1/4 oal or 4 1/4 center of spline to toe peg?
Hope you find some thing.
