engine 826
Started by pepeducat, June 03, 2015, 12:48:19 AM
 [thumbsup] Cool.
Looking forward to the fin build.
Nibor
Quote from: koko64 on June 03, 2015, 11:41:59 PM
[thumbsup] Cool.
You and me both! [popcorn]
Don't you get any ideas. Step away from the thread. ;D
Quote from: Raux on June 03, 2015, 08:00:10 PM
Sooo ive always heard the cases are different for the smaller motors. Just bearings?
Crank to transmission input shaft is the same, but center to center between the transmission input & output shafts are smaller on the 'small case' engines than the 'large case' engines.
More on that here:  http://bikeboy.org/duccapacities.html
MotoPsycho
Quote from: koko64 on June 04, 2015, 04:27:02 AM
We need a like button.
Cr  anks are different diameter too?
Bike boy info seems to indicate that Pepe will need to be mixing and matching parts to suit, and customizing where necessary. Appears he has the means and ways to do it, and contacts to get all sorts of parts. I'll be watching this build with interest.
I do love this idea.
Although would love to see a 1198 with 749r crank put together. Almost 2:1 oversquare. More than 1199. Puts it at 1030cc iirc. Short ti rods lightweight piston. Knife crank. Ti valves. Would be a screamer.
pepeducat
Quote from: koko64 on June 04, 2015, 06:12:53 PM
Indeed, the crankshaft must be touch on the masses and the alternator housing is to be machined and highly modified because the crankshaft 900 is longer 15mm alternator side than 750.
The whole project is based on two machining
pepeducat
The crankshaft machining is to create two chamfer on the masses to rotate freely in the housings
in the second pic, is the interference on the relative top or sides of the crank?
pepeducat
the interference on the  sides of the crank and the distribution shaft
Quote from: pepeducat on June 17, 2015, 01:19:53 PM
Ah.  so you will shorten the crank lobe?
