engine 826
Started by pepeducat, June 03, 2015, 12:48:19 AM
pepeducat
I have plans to mount a Café Racer with a 826 engine ... But what is it 826, Ducati has never produced ???
In fact I'll put a crankshaft 900 in a 750 to reach 826
So I have this, a low engine 750
a 750 Paso gearbox with its clutch
900SS the crankshaft 91 while polite
a pair of cam shaft NCR7
a flywheel 600SS, 440gr against original 1880gr [evil]
A pair of cylinder heads Paso
MotoPsycho
I'm really curious to see how this is going to pan out. The way I understood it, there is some serious compatibility issues with the "small block" motors and the 900's. I'm curious to see how it would go the other way. 750 crank in 900 case with 94mm pistons. I got 853 cc but way oversquare. Like 1.5 bore to stroke ratio.
Keep us posted pepe, this is gonna get good.  [bacon] [bacon]
Quote from: MotoPsycho on June 03, 2015, 04:04:01 AM
Eric at clubhousemotorsports has an 853 motor just like that. It sounds more like a 748 than a 900 with the short stroke.
Goes pretty good too.
*bookmarked..
I have 3 paso 750 engines laying around in my garage...
Send me a PM if you're interested in some modified F1 heads for that thing...
pepeducat
In fact I do the closet background in the various workshops that I know
826 And then, I've never seen or heard that someone tried
But I have a lot of work on the crankshaft and alternator housing
Quote from: pepeducat on June 03, 2015, 02:56:15 PM
http://www.ducatitech.com/info/bore.html
Bore = 92
stroke = 61.5  (paso 750, pre 93 elefant 750, indiana)
= 817.8 cc
Bore = 92
Stroke = 64  (851,888)
= 853cc
Bore = 94
Stroke = 61.5 = 853cc
904cc 900 engine is 92mm stroke
According to the calculator 68 stroke (900) & 88 bore (750) =827
The early Elefant Dakar bikes went from 750 up to 853 before they went to 904? That right Tiz?
Quote from: koko64 on June 03, 2015, 07:20:07 PM
Yeah, the old style Elefants used the Pantah RHS clutch cases.  First one was the plain old 750 paso style, then in 86 they bumped it to 853..  in 88, they moved to the 906 style case with 5spd and 904 and in 90 they used the 907 case with 944cc
i was thinking the opposite, paso crank with 900 pistons..durr..
bore = 88 (750 pistons)
stroke = 68 (904 engine)
= 827.3 cc
now i'm happy
Sooo ive always heard the cases are different for the smaller motors. Just bearings?
Pepe, how you managing piston height/clearance to the combustion chamber roof and valves? Is there an issue with the longer stroke and short cylinders?
Quote from: koko64 on June 03, 2015, 08:11:57 PM
They've got plenty of metal to relieve but I don't see the additional stroke requiring too much if he can machine that crank.  i would lighten and "knife" it like the SPS models just to get rid of a lot of metal before worrying about the pistons..
pepeducat
I'll do a calculation to determine the height of a wedge that will replace the base gasket and have optimum squish.
It will be laser cut or water jet in an aluminum plate and I could bump my cylinder at the right height.
