engine 826
Started by pepeducat, June 03, 2015, 12:48:19 AM
Dirty Duc
I would machine the layshaft...
Quote from: Dirty Duc on June 18, 2015, 06:16:01 AM
depends on how much you need to cut off....  you could probably deal with it by lightening and knife-edging the crank and shorting it just a bit.
pepeducat
Quote from: ducatiz on June 18, 2015, 04:32:59 AM
Ah.  so you will shorten the crank lobe?
I will not change the alternator housing ;)
pepeducat
Cylinders and pistons for 826 and received the vilo should return next week for a first motor mounting see if everything fits well  [evil]
pepeducat
Quote from: ducatiz on June 18, 2015, 09:52:26 AM
[thumbsup]
Very interested to see the power characteristics of this stroker Vs the more common shorter stroke bigger bore versions.
There are some talented people around.
pepeducat
MotoPsycho
If it's along the lines of a typical stroker at least with old hot rod motors, it might only be 90 horse but the torque will be insane.
pepeducat
That's it and that is what is sought [evil]
Looking forward to what the dyno has to say. Very cool. [thumbsup]
