New Ignitech TCIP4 In Need Of Assistance
Started by terse750, July 19, 2015, 10:58:05 AM
terse750
See...thats the thing.
Its a 2001 carb 750 bike with a 2002 EFI 750 motor swap ... [wine] Yeah...I got the wrong motor.
Anyhow Ignitech said they had a "plug and play" adapter set-up. I have a picture Igni sent but I guess no attachments
Something tells me I'm in neck deep without a paddle.
I'll start going through things when I get a chance. I really don't know where to start [thumbsdown] not fun
Take some pics of the adapter from IgniTech, and post 'em up.
And the pic(s) from IgniTech as well.
terse750
I'll be able to work on her Friday.
How do you guys post pics? Photo bucket ?
Nibor
i cheat haha. post privately on facebook, then copy the URL and paste it in here with the image coding.
terse750
So she's turning over! Got fuel flowing!
I've had her on the charger all day and she finally started showing signs of life.
Going to try some more and check plugs excess gas.
I tried the plugs both ways! No difference so far.
Damn! Damn! Daaaaaamn! so close!
terse750
Now she's stumbling wanting to start!
Killed the battrie... [clap]
Some backfiring and carb spitting which I guess is par for the course on a non-tuned bike?
terse750
SHE ALIVE!!!!! [thumbsup]
Well she starts! Only thing is she sounds like she's running one one cylinder and can't give any throttle at all without killing...?
Any tips?
I've yet to try and hook up the laptop to run TCIP4 programming, maybe this can help?
There's a facility on the program that tells you how each cylinder is firing which is useful. You will be able to see how they are firing in real time.
Check the plugs, plug wires and coil wires again.
Did you run the previous motor with the FCR's, or did you put them on just now, along with the '02 motor and Ignitech?
terse750
#28
You guessed it! FCR's are brand new
Looks like I need to tune and maybe rejet, yes?
Yes a task in itself,  but check the wiring, etc if its only running on one.  The carbs should at least be set close enough for the bike to run.
